Constant power for gauges?
Old Apr 3, 2017 | 11:12 PM
TheIronYuppy's Avatar
Hi forum
I'm installing AEM gauges. The boost gauge is being problematic. It powers up but doesn't display boost levels. I have checked the vacuum hose and it is flowing freely. The sending unit also checks out ok.
I have read that this problem *may* be fixed by powering the gauge from a 12V circuit that remains constant during cranking.
Apparently what happens is the gauge resets during cranking, so it doesn't calibrate for the vacuum it's receiving.
Where can I find a 12V circuit that isn't interrupted by cranking, but will shut off when the ignition is turned off? Obviously I don't want my gauge to be on all the time; it'll drain the battery AND look stupid doing it.
Old Apr 4, 2017 | 02:28 PM
BradMD_96's Avatar
I know the windows will still go up/down and headlights can stay on during cranking (and go off with ign off). Have a look/think around what stays on when you crank the engine over and which circuit is the easiest to tap in to.
Old Apr 4, 2017 | 03:29 PM
There's a 40a fusable link under the hood that I *think* is the circuit for the windows.
Anyone know for sure?
As far as I can tell the windows don't have a dedicated fuse in any of the other panels.
