Audio system question.
Old May 4, 2017 | 08:17 PM
krdoloroso's Avatar
When I bought my car, these were already here.
They were hidden under the mat of the trunk and squeezed by the rear seats.
What's each wire/cable for?
Thank you!!!
Old May 4, 2017 | 08:26 PM
Blue Dream's Avatar
I drove ttrank's car solo
Please post threads in the appropriate forum. That being said I'm moving this to where it belongs ummmkay?
Old May 4, 2017 | 08:45 PM
krdoloroso's Avatar
please do
Old May 5, 2017 | 12:16 AM
BradMD_96's Avatar
Thank you!!!
Those are for an amp.
Black - Ground
Blue - Power (check it's the same on the battery end with a fuse)
Little blue - Switched Live (Ignition on) Signal for power on (from stereo)
Black/Silver - RCA from stereo for audio signal
Aux - not sure, could be for signal or possibly a volume control (subwoofer control) or other
Old May 11, 2017 | 08:43 AM
parapraxis24's Avatar
Black - Ground
I would also add that the Black (ground) and Blue (Batter +) should avoid touching at all costs. It seems likely that the fuse was removed at the battery on the Blue wire, but you don't want that live wire shorting out anywhere on the chassis and starting a fire.
