XM/AUX unselectable after dead battery
Old Jul 11, 2017 | 07:21 PM
tha_ape's Avatar
G35 6MT Coupe
I have an isimple auxiliary input installed in my 2006 G35 Coupe. It also has factory XM radio installed. Usually, pressing "radio" out cycles through AM, FM and Aux. I replaced my battery after it died and now the system only cycles through AM and FM (it doesn't go to XM [factory option], or the . AUX mode as before).
The AM/FM radio works fine, but somehow it's not recognising the XM/Aux mode.
Does anyone know how to fix this?
Old Jul 12, 2017 | 05:29 AM
telcoman's Avatar
Veteran: Army
When my previous 06 G35 6 speed needed a battery after pricing them the dealer was only $20 more than other shops
The dealer replaced my battery and everything worked when I left
Same with my current 2012 when i replaced the battery a few months ago
Everything worked when I left the dealer
Good luck
Telcoman
Old Jul 12, 2017 | 08:32 AM
tha_ape's Avatar
G35 6MT Coupe
Yea, threes not much to replacing it, I did it myself and checked the Infiniti shop manual just to be sure.
I think the problem came from having a 100% dead battery or trying to charge it while it was connected to the car. I modified the input with an isimple audio adapter that basically acts as a channel on the XM radio selection (says AUX 1 instead of a channel number), I suppose the problem is there, but it's nothing the dealership is responsible for. I was hoping someone had a similar issue or knows a quick fix.
I may end up having to break out the volt meter and check connections underneath the gear shift (where I have the audio/video stuff). I can still mirror my phone on the nav display. And my backup cam still works so im pretty sure the problem is strictly I the audio side. Hopefully I don't have to pull the radio again, that's a pain in the butt!
Old Jul 13, 2017 | 09:22 AM
tha_ape's Avatar
G35 6MT Coupe
Fixed it
Ok, I'll post the fix in case anyone else runs into this issue.
Got an email from isimple, I just needed to reset the device! Simple solution!
I did it and it worked. Free solutions are the best.
