Air Bag Light Flashing
Old Mar 2, 2005 | 01:31 PM
ARTofAWD's Avatar
I just had a couple of amplifiers installed in my car along with new speakers. But for some reason my Air Bag Light on the dash is flashing. The install place tells me this is normal with some cars when the power has been disconnected for some time and that it might reset by itself. Well it hasn't reset and I can find no proof that the light would come on if the battery is disconnected for a period of time. Now my question is do I have to take the car back to Infiniti to reset the fault or do you guys think that a wire may not be hooked up correctly. I did check the Air Bag fuse and it's fine. I peered underneath the dash without taking it apart and I cannot find any obvious wires handing disconnected.
Anyone got any ideas? I can't make it back to the audio shop for a few days but I sure would feel happier if my Air Bag light wasn't continually flashing at me.
Thanks in advance
Old Mar 2, 2005 | 02:20 PM
xswl0931's Avatar
Usually that flashes if the battery WASN'T disconnected during some sort of install where certain wires are disconnected. You can clear the light yourself. I believe the steps are:
1. with car turned off
2. put key in and turn it enough to enable accessories (don't actually start the engine)
3. when the air bag light comes on, then turns off (or starts to blink), turn car off
4. count at least 3 seconds
5. repeat steps 3-4 three times
Timing is important. If this doesn't work, you might try searching www.my350z.com for "air bag light" on the proper procedure as this is off the top of my head and the timing may not be right.
If the light comes on again after you do this, you should take it to the dealer.
Old Mar 2, 2005 | 02:45 PM
ARTofAWD's Avatar
You guys are great, thanks for the advice. I found the old posting and it worked !!
Try this to reset the light:
1. Turn ignition switch from OFF to ON
2. Within 1 second after bag warning light is on for 7 seconds and turns off, turn off ignition switch.
3. After ignition switch is turned off, wait for more than 3 seconds.
4. Repeat steps 1-3 two more times (Perform 3 times in total)
5. Turn ignition switch ON again.
Now you are in diagnostic mode.
Hopefully you will now see the air bag light stay on for 7 seconds and then turn off for 2 seconds then on for 3 seconds, off for 2, on for 3,2,3,2,3... If not, there is a legitmate problem and you should go to the dealer. If you do get the 2,3,2,3 repeating pattern, then turn OFF ignition for a least one second to reset the light and bring you out of the diagnostic mode.
Luisgalvan33
Jul 19, 2018 08:16 PM
privatecorye
Steering & Suspension
May 31, 2016 01:56 AM
ghost_g35
Aug 7, 2015 10:31 AM
ZacDesu
Jul 14, 2015 11:13 PM
