Has my bcm or body control module gone bad?
Old Apr 26, 2018 | 07:53 PM
Flarewater's Avatar
So recently my door locks on my 04 g35 coupe went. I decided to go ahead and change the drivers side for now, so i took the door apart completely, i needed my car a day later and had to put the bad lock actuator back in just to drive it, after i out it back in, none of my door locks or even windows on both my doors work. What could be making the issue? I didnt even touch the passenger side, why has it failed, the windows worked just fine before this. Thanks
Old Jan 24, 2019 | 08:36 PM
anusin's Avatar
G35 Coupe Everything Stock
Are the other windows not working completely or just not with the drivers side door actuator. Can you use the passenger to roll up the passenger?
Old Jan 25, 2019 | 11:32 AM
cswlightning's Avatar
You didn't plug the driver side window switch assy back in correctly, or messing around it caused a wiring issue to surface.
Old Jan 26, 2019 | 02:14 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
I guess I'll respond to the necro thread. When you press the passenger side buttons the signal is always sent back to the driver controller first. The driver controller then sends the signal to the BCM and the BCM sends the signal back out to the window, lock, etc. Like CSW said, you probably didn't plug it in correctly. There's also a pretty decent chance that you blew the fuse if you were trying to do this work without disconnecting the battery first. It's somewhere in the IPDM but since this is a NECRO THREAD I'm not going to bother looking it up.
Old Jan 26, 2019 | 03:54 PM
LOL I didn't even notice
Silver tiburon
11
Apr 13, 2020 01:37 AM
Heinz
Oct 3, 2013 08:01 AM
Heinz
May 8, 2011 05:19 PM
