Parrot Bluetooth removal help ASAP !!
Old Jun 19, 2019 | 03:42 PM
Sl33zyvq's Avatar
2004 g35x sedan
I have an 04 g35x Sedan . My battery keeps draining after I replaced the battery and terminals . I have an old parrot Bluetooth that I figure is connected to the radio . I’m guessing it’s parasitic drawing the battery when it’s on sleep mode . I can’t find videos to remove the parrot or the radio . Help please ! Also did anyone else run into his issue ?
Old Jun 19, 2019 | 03:53 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
Was your battery draining BEFORE you replaced the battery and terminals? Typically the number 1 cause of battery drain is from the cd changer, pull the fuse and see if the discharge goes away, then you will know exactly which circuit to troubleshoot.
If you can't find videos about removing the radio I'm shocked, there are hundreds of thousands of them on youtube just type in "g35 stereo removal" and let the games begin.
Moving this thread to the appropriate Audio/Visual subforum.
Old Jun 19, 2019 | 03:58 PM
Sl33zyvq's Avatar
2004 g35x sedan
Yes my battery was drawing before I replaced the battery and the terminals . It was doing the same thing now with the original battery
Old Jun 19, 2019 | 03:59 PM
G35fromPA's Avatar
I had one in my old '04 Coupe. It was installed by a shop, but ultimately was pretty easy to remove when I installed my own aftermarket head unit. There was no splicing done, etc. and there were just some additional wires clipped into the main radio harness.
If you look in the Audio Video & Electronics forum (https://g35driver.com/forums/audio-v...lectronics-20/) you'll find good DIY for removing the radio, etc.as well as youtube. Lots of videos on youtube for removing the radio and for the Parrot bluetooth kits (usually Mki9200).
Old Jun 19, 2019 | 04:27 PM
Sl33zyvq's Avatar
2004 g35x sedan
Do I go under the hood and remove that fuse ?
Old Jun 19, 2019 | 07:19 PM
cleric670's Avatar
BANNED!!!
No, driver side footwell there is an access panel to Fuse Block - J/B which handles all the stuff like the radio.
sammy_G
Archived Sales
Nov 28, 2009 01:11 AM
