Dual Zone AC on Double Din Panel Replacement
Old Jun 29, 2019 | 05:31 PM
gemme207's Avatar
2005 G35x Sedan
Hello,
I have a 2005 G35x Sedan and want to replace the original radio with a double din unit and add a head unit, although I have the dual AC zone button and it seems that all of the OEM double din units don't have that button. I'm not too concerned with not being able to use dual zone (I could always solder it) but I'm wondering if those panels and the harness are actually compatible with my car?
Thanks.
Old Jul 1, 2019 | 04:58 PM
eric1254's Avatar
Stock as of now
I believe you will have to specifically find a double din with the dual button. I've seen some with the single and some with dual to fit the specific trim of your car.
Old Jul 2, 2019 | 04:40 PM
LoSt180's Avatar
Yes, they will work with your car, you'll just lose that functionality. Harness is compatible.
Old Jul 3, 2019 | 12:24 AM
Wrathernaut's Avatar
Gentle Manne of Leisure
You just have to swap the button over. Details are in the main FAQ: https://g35driver.com/forums/audio-v...urce-list.html
Old Jul 3, 2019 | 02:35 AM
Urbanengineer's Avatar
Boomers reunion?
Old Jul 3, 2019 | 08:48 AM
LoSt180's Avatar
Boomers reunion?
Swapping the button over is only necessary if you want to keep the dual functionality.
Old Jul 5, 2019 | 02:17 AM
True, but from the post, I guess that is desired.
Old Jul 5, 2019 | 04:54 PM
LoSt180's Avatar
I read the OP that he was wondering if the panels were compatible, like asking if there was a wiring difference between them, which there isn't. At least now he has more info than he asked for.
mliu66
Audio/Video/Electronics
May 26, 2014 06:10 PM
guido631
May 14, 2014 03:15 PM
chatt350gt
Oct 3, 2011 12:52 PM
phatbuddha
Archived Sales
Feb 18, 2009 06:58 PM
