Help with ipod Integration
Old Mar 22, 2005 | 07:18 PM
DJM's Avatar
DJM
OK, so I want to hard wire an ipod into my G through the SAT connection. What I need are the model numbers of the exact cables I will need? Which Belkin cable supplies the ipod power and has a 3.5mm line out where you can plug a 3.5mm to RCA cable from it to the PAC cable?
Thanks
Old Mar 22, 2005 | 08:07 PM
blksnake's Avatar
http://g35ipod.com/home.php
Old Mar 23, 2005 | 11:19 AM
DJM's Avatar
DJM
Thanks, that site is very useful. I found the correct cables for the install.
Now, does anyone have any suggestions on where to run the wires and mount the ipod? I was thinking through the cubby hole where the NAV would go, I obviously don't have the NAV. But then where do you plug the Belkin power supply into? I guess you would utilize one of the cig. outlets on either side of the radio.
Any suggestions would be appreciated!!!!!!!
Thanks
Old Mar 23, 2005 | 11:42 AM
ikSardarG's Avatar
I personally connected mine through the cig. lighter in the center armrest console. it was unused since I purchased the car - and I finally found a use for it. I drilled a small hole through the console and the Belkin then feeds my PAC AAI-NIS unit which is hidden underneath the console (near the shifter).
I have a pretty stealthy install, and to hide the iPod - all I do is lift the armrest and put it inside. Works great, since when I shut off the car - the Ipod pauses as well.
For you, I would recommend that you pick-up a female cig. lighter connector from RadioShack (can't be too much $$). I would then find a switched 12v+ lead from behind the console and basically make a hidden cig. lighter which your Belkin can use as a dedicated/hidden power source. You can then run the Belkin wire from the navi cubby, behind the dash to your new cig lighter and you will have a pretty hidden install. It should look pretty good...
Just a suggestion anyways...
Old Mar 23, 2005 | 05:01 PM
DJM's Avatar
DJM
Cool, thanks for the great ideas. When you say,
"find a switched 12v+ lead from behind the console and basically make a hidden cig. lighter which your Belkin can use as a dedicated/hidden power source",
the switched you are referring to would mean that the power to it turns off when the ignition is in the off position?
Can I just tie into one of the iwres leading to current cig. power outlets on either side of the stereo?
Thanks again.
Old Mar 23, 2005 | 05:33 PM
ikSardarG's Avatar
Yes, that's right - That is exactly what I would do. Just make sure that you don't have too much stuff running from one 12v+ lead... That'll be a fuse problem for sure.
seagrasser
May 3, 2022 09:43 AM
Diode Dynamics
Accessories-Vendor
39
Nov 30, 2021 02:28 PM
Mad A
Not G35 Related
Dec 8, 2015 01:45 PM
the93owner
Sep 27, 2015 05:23 PM
