How to remove center console/silver piece for 2005
Old Apr 7, 2005 | 04:30 PM
trebien's Avatar
Anybody written this up, yet? I need to get in behind the ashtray to hardwire my X50 rader detector and want to mount the remote unit in the ashtray.
Looks like I will need to remove the side panels of the console and the aluminum cover panel/shift surround. How/what order do things come apart?
Thanks.
Old Apr 7, 2005 | 10:42 PM
docron1's Avatar
From: Centerburg, Ohio (the geographical center of the Buckeye State)
Thanks.
ahem...Kia.......lol
NO, no one has written this up yet.
From remembering pictures from the 05 service manual, you do need to remove those side panels on either side of the HVAC unit and the piece around the shifter. Do a search of my personal posts and I posted pictures of the HVAC unit from the service manual and how the pieces snap together. I don't think there's any order you have to remove them. As long as you remove the gloveboxes and driverside under steering column panels first to access the HVAC side panels.
I'll try to find my post when I have more time.
doc
Old Apr 7, 2005 | 10:45 PM
docron1's Avatar
Found it...
here you go...
https://g35driver.com/forums/audio-video-electronics/40671-2005-instrument-panel-changes-dash-disassembly.html
doc
Old Apr 8, 2005 | 11:18 AM
trebien's Avatar
Thanks - I guess I'll study the pictures then "use the force..."
Old Apr 8, 2005 | 04:21 PM
SolidForce's Avatar
shift ****, the silver lining by the shift ****, under the steering wheel (careful of the DCC hose), left side of HVAC, Right side of HVAC, a couple of screws and pop it goes!
-SF
Old Apr 8, 2005 | 05:00 PM
docron1's Avatar
oh yeah.....be careful when you drop down the panel under the steering column. There is the in-cabin sensor (that little grille looking thingy by your right knee when you sit in the driver's seat) and if that gets jogged loose, your AC controls will be messed up and blow 75 degree air.
doc
Old Apr 8, 2005 | 05:12 PM
SolidForce's Avatar
doc
ya trust me it sucks.
-SF
<-- did it like a dumbass
Old Apr 8, 2005 | 07:51 PM
GRider35c's Avatar
and if youre driving around without your A/C controller pulgged in it will default to automatic... i had to drive with 65 degree air blowing and it was annoying as hell!!!
Old Apr 11, 2005 | 10:45 PM
trebien's Avatar
Is there any other information about which pieces are screwed (under dash panels) and which pieces are clipped - simply "yankable"...
From what I understand, unscrew the under dash panels, remove the side pieces of the center stack (looks like screws up top), then what? How does the shifter pieces come apart? I see screws on the sides of the center console, down below the elbow rest.
I've taken cars apart before, but the G's interior connector points are a little harder to find.
Old Apr 12, 2005 | 03:31 AM
GRider35c's Avatar
the side pieces of the center stack are screwed under the shifter piece...
the shifter brushed aluminum pops out from the bottom, use a screwdriver with cloth to pry the bottom up, nearest to the center stoirage... then youll see the 2 screws
StreetStandard
Engine-Vendor
117
May 22, 2020 08:21 AM
R1 Autoworks
Exterior-Vendor
Jul 3, 2019 07:16 PM
StreetStandard
Suspension-Vendor
Jan 18, 2016 03:36 PM
StreetStandard
Exhaust-Vendor
11
Jan 12, 2016 03:21 PM
