Anyone else have noise
Old Apr 11, 2005 | 12:35 PM
realgone's Avatar
Widdle ya into kindling
Got my car back after two days for a stereo install. Sounds great, however, there is a little bit of noise. I had this stereo in my Jetta and had the same problem.
Could it be the amp?
Anyone else have the same problem?
It sounds great, but I really do not want the noise. Can someone give me some advice. Here is a link to the pictures of the install.
Custom Stereo Pics Link
Old Apr 11, 2005 | 01:07 PM
Beowulf's Avatar
The fact that you had the same problem in the jetta probably means its the amp... Make sure its grounded correctly and try to "quick wire" in a second amp and see if it helps. Then you will know if its the amp or not. Noise is common problem of a bad amp or install; you might ask your local shop for some quick advise..
Marlin84
Apr 1, 2020 12:52 PM
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
RichardP9
Drivetrain
Oct 26, 2015 11:25 PM
dcsbh1
Oct 1, 2015 03:15 PM
alinero718
Sep 27, 2015 09:35 PM
