Looking for advice on in-dash headunits
Old Apr 20, 2005 | 04:40 PM
limeg35's Avatar
I've been pondering this for awhile, and I can't seem to come up with a good solution. I'm trying to find a suitable headunit for my G that will support DVD, Radio, CD, Navigation, and preferrably TV. I first tried to find a double-din unit where the screen was the front of the unit (unlike a single-din motor-out screen) and the only one I could find (an Eclipse model) did not allow you to play DVD's AND use the navigation at the same time.
I dont think any unit will allow you to play movies and navi at same screen at same time, maybe as split srceen, but you can have them play at different zones(screen) at same time.
Any solution must be able to play DVD's and navigate at the same time (not keen on the idea of "memory navigation" where a route is loaded into memory, but I'm open to it), and it would be nice if the unit was touch screen
All you need is an DVD/CD changer, for AVIC's
Old Apr 20, 2005 | 05:24 PM
Sooner97's Avatar
I don't think there's a unit out on the market that will enable you to use your nav and play a movie simply because all the units only come with a single DVD-ROM drive and the Nav info are on a DVD. But you should check out the new Eclipse unit (can't remember the model number) but it has a built in hard drive that the nav info is stored on, so I'm sure you can watch movies while the nav is running. I'm not 100% sure about this but you should check it out. Just be aware that it won't be cheap.
Old Apr 20, 2005 | 05:39 PM
GRider35c's Avatar
the kenwood double din lets you do both navi and dvd... the navi is a seperate unit...
also, eclipse navi does not have a built in navi, its a dvd-rom u need to insert...
so far ALL of your info has been 100% incorrect, if you dont know something dont post it! it confuses most people!
Old Apr 20, 2005 | 05:41 PM
GRider35c's Avatar
adam, i say go with either the Eclipse AVN 5435(?), or the Kenwood excelon (forgot the model number)... the kenwood lets u watch dvd's while running navi!
if u got any questions ask me, ive done double din navi/ dvd on both my 04 and 05 G35 coupes...
Attached Thumbnails Looking for advice on in-dash headunits-copy-dsc00731.jpg   Looking for advice on in-dash headunits-dsc01688.jpg
Old Apr 20, 2005 | 05:49 PM
GRider35c's Avatar
i heard sound quality kicks a$$!!!
other than that, i dont know anything else about the unit...
good luck, and see my DIY for instructions!
Old Apr 20, 2005 | 08:41 PM
limeg35's Avatar
Originally Posted by AdamsInfiniti
Just for clarification, I said *play* them at the same time, not *watch* them at the same time. I realize that one of them is going to be using the screen at any given time, but if I have a route, I don't want to have to take the DVD out that's playing for the people in the back just to map my route. Nor do I want to have to cancel a route in order to play a DVD.
I had a kenwood unit that did this; it had a seperate reader box for the navigation which was mounted remotely.
The double din size head unit have two drives(AVN, not sure on kenwood's) so you dont have to swap out the disc, the AVIC only have one drive, so you do need to swap disc out, but like i said earlier, just need an changer to avoid swaping the disc.
as far for quality goes? I think they are pretty much the same, it just depends on what feature on them you like more, like Alpine's iva-300? has sense touch screen that you can feel you are pushing a button, to change EQ setting on AVN's? you can just drag your finger across the screen and it will adjust acorrdingly, and it has better sound adjustment, AVIC it has...well lower price and deteachable face, but the single din's motor might wear out couple years down the road.
Old Apr 20, 2005 | 11:30 PM
GRider35c's Avatar
yeah the AVN has 2 drives, but one is CD and the other is DVD, so yeah you need to swap them out!
kenwood is a seperate unit!
Old Apr 21, 2005 | 02:56 PM
G_riot's Avatar
So Grider35,
The 5435 HU is the new one replacing the 2004 model(AVN 2454). Which the 2454 had a 2v preout and the 5435 has a 5v preout w/esn security. Can the 5435 utilize the navi in one zone and utilize a DVD movie in another zone? Or is some mod needed for this? I was just curious because Adaminfiniti was hitting the same subject i was thinking about doing myself.
Old Apr 21, 2005 | 04:18 PM
GRider35c's Avatar
Originally Posted by G_riot
So Grider35,
what do you mean "zone"??
there is ONE slot for dvd, either you put the navi OR a movie in there, cant put both!
Old Apr 22, 2005 | 04:57 PM
G_riot's Avatar
What i meant by zone(display screen). So it would be better to go with the Kenwood HU since the Nav comes in a seperate unit. So,you could utilize the Navigation on one screen and play a DVD on another screen.
Old Apr 22, 2005 | 11:10 PM
GRider35c's Avatar
there isnt 2 screens, theres 2 units to put dvds in, one for navi and the other for movies...
