Bose RMS output?
Old May 10, 2005 | 07:01 AM
Shonuff's Avatar
Bose RMS output?
Anyone know what the rms power output is of the bose amp to the stock 6 speakers (8 if you count the tweeters, but 6 channels). Wondering if i can run a decent 4 channel amp off the power already there or if i'll need to run another line from the battery. (yeah, i'm lazy)
Old May 10, 2005 | 11:24 AM
rcdash's Avatar
well, i believe the wire is 8 gauge running about 15 ft and I believe the infinity marketing material reflects peak power (so cut in half) - I would estimate around 25W x 6 (for the coupe) - maybe less for the first 4, more for the 6 x 9 - but around there. Please also note that that reflects 2 ohm speakers, so if you stick in 4 ohm, the output will be even less.
Old May 10, 2005 | 02:33 PM
Shonuff's Avatar
hmm...that's about what i figured. I thought i remembered seeing that people changed out their speakers. Anyone do that and not change the amp? Cause I don't see any 2 ohm speakers out there.
Basically I was either gonna change amp and speakers, speakers, or just tweeters. I really want better highs and i've read other posts about changing just the tweeters, but again these are 4 ohm. But if my memory serves correctly, the stock ones are 4 ohm as well. So I guess that's ok, but will that make much of a difference?
Old May 10, 2005 | 02:52 PM
g35john's Avatar
If the bose amp put out more the 10 watts RMS I would very impressed. Any aftermarket 25 watt RMS amp wiill kill the stock system.
Old May 10, 2005 | 03:00 PM
FrizzleFry's Avatar
i just put in my boston acoustics (4ohm) SL60 and SL65 running off the stock BOSE system. no problems. it is definitely cleaner sounding... waiting to pull the 4 gauge power cable and install my amps... working out the design right now.
Ninjay16
Audio/Video/Electronics
11
Feb 26, 2018 06:14 PM
DEMoLITIoN
Apr 20, 2016 06:57 PM
JoeMac
Sep 28, 2015 12:28 AM
JustinMKN1
Sep 18, 2015 03:40 PM
