XM and Sirius interchangeable?
Your also going to have to change the antenna. Running the antenna wire is the labor intense part; you may be able to cut it and splice on the XM antenna, but why switch? The differences are marginal... You would probably realize that a switch is wasted money after you go through with it..
Find someone who wants to trade their XM for Sirius... Or eBay.
Changing the antenna is not a big deal. It runs around the rear window and into the trunk under a little tape and a seal. Whooopie. I put a mini XM antenna on my G in the normal spot in about 10 minutes. And I had to dremel the notch on the lip of the trunk opening under the seal. His will already be done.
This is a breeze. The harder part will be finding the XM receiver at a reasonable price or fair swap.
I can tell you it would be very worthwhile for me if I were you. I strongly prefer XM (as a one-time subscriber to both).
Z1Motorsports
Suspension-Vendor
56
May 31, 2020 01:56 PM
prabhacar
Feb 10, 2004 09:48 PM
