upgrading bose system, please help
Hey guys. I am planning on upgrading my system. My plan is that I will keep the bose head unit and amps and will use Audiocontrol lc6 to convert spearkers level to rca.What I have right now is a Diamond Audio D7056 (i am pretty sure this amp is powerful enough to run the whole system), and diamond audio hex s600s component for the front. My questions are:
1. Should I just not used the rear side speakers and replace the bose subs for new 6x9 and add a sub in the trunk?
2. Or just not used the bose sub and keep the rear sides and add a sub in the trunk
3. Or maybe used everything as original factory, excepted upgraded the rears and 6x9 subs???
4. or use everything (sides and 6x9, and add a sub in the trunk).
Any comment on the diamond audio amp d7056 is welcome. I want to thank you guys in advance for the response, and I am not an audio xpert neither. so any help is greatly appreciated
htn
htn
RMS Output Power
50 Watts x 6 @ 4 Ohm Stereo
100 Watts x 6 @ 2 Ohm Stereo
200 Watts x 3 Bridged @ 4 Ohms
RMS Output Power
Frequency Response: 3-50,000 Hz
Signal-to-Noise Ratio: 102dB
THD: 0.02%
It look like it will be plenty, but the questions is, can it do 5 channels? so you can have 50x4 plus 200x1, for the money I probably go with Memphis big Belle it will give you 75x4 plus 600x1 @2ohm or 1100x1@1ohm, and it will be lil bit cheaper too, but since you said you "have" it already? then it dont really matter now
If you go with D7056? then you dont need factory amp no more, I would change out the rear deck speakers, it dont have to be 6x9s
, I would take out the rear side speakers or just leave it and not hook it up, cus its lil too close to your ears, and besides, it dont have much of mounting depth. many ppl have opt to have only fornt stage, it depends on what you like tho.
RMS Output Power
THD: 0.02%
