LOC - Anyone using a PAC AOEM-NIS2 with factory connectors ??
Old Jun 19, 2005 | 09:04 PM
neils's Avatar
Just curious, I saw that PAC has a LOC with factory connectors, so one doesn't have to hack up the factory wires in the trunk in order to use a standard wired LOC like the PAC SNI-35 or the Navone NE-774V. Any experience with this model ??
http://www.pac-audio.com/oem1kits/oem1search.htm
http://www.pac-audio.com/oem1kits/ao...or+AOEM-1+kits
Also curious, why a LOC?? If you tap into the wires before the Bose amp, it should be a low level signal, and therefore you don't need to modify it with a LOC (which is used for high level amplified signals). I would think all you would need to do is to splice into the wires and add some RCA connectors. But then again, splicing into any wire breaks the shield and can introduce unwanted noise...hence the idea of using a LOC in the first place...
Thanks in advance for your time in reading and answering this question
Neil
Old Jun 20, 2005 | 10:33 AM
sillief00l's Avatar
The factory headunit, before the BOSE amplifier is not a low level signal.
In any case, i am currently using the PAC unit right now.
Sounds awesome.
Old Jun 20, 2005 | 02:51 PM
rcdash's Avatar
Like he said - the signal coming out of the clarion HU is amplified. That said, it's been measured to be only 2.2V at maximum volume. So you could treat it like a low level signal for many aftermarket amps.
However the AOEM-NIS2, although a PIA to install behind the HU, does provide clear RCA signals without any splicing whatsoever. Even a remote start wire is provided. My rationale for using it was that I could very easily go back to stock Bose anytime I needed to.
I have the gain on the AOEM-NIS2 turned up to MAX but ever since installing a sub, I do notice some noise (low Hz rumble) from the HU RCA outputs (even when it is off - so not sure this is an AOEM-NIS2 and/or HU issue or some noise is coming from somewhere else - but it is so hard to hear without maxing out the gain on the sub that I have not worried about it). If I play directly from my carPC - there is zero audible noise even on max gain (SB Extigy powered) when no signal is playing.
Old Jun 20, 2005 | 04:02 PM
Espresso's Avatar
I did exactly what you said by tapping into the wires before the Bose amp and converted them to an RCA plug. It was a quick and easy way of getting a signal. It sounds fine so far hooked up to a JL 300/4 but I'm not an audiophile.
Old Jun 21, 2005 | 10:58 PM
GUM35's Avatar
Espresso: Are you using a PAC or VEN to convert them to RCA or just tapped with an RCA cable? The reason I ask is because I was about to do the same thing and wasn't sure if I really needed the VEN I bought or use the the RCA connectors my adapter has. Thanks.
Old Jun 22, 2005 | 12:04 AM
Espresso's Avatar
I used these and tapped into the signal wires from the HU harness.
Old Jun 22, 2005 | 03:21 PM
GUM35's Avatar
Ah great, I was thinking of doing the same. Do you have the premiums sound? I take it sounds good? Better than stock I take it. Thanks.
Old Jun 22, 2005 | 03:28 PM
Espresso's Avatar
Yes I have the Premium package with Bose speakers but no, they do not sound better than non-Bose. The new aftermarket speakers with new amp do sound better though even while using the current HU.
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
andrewvk
Engine - Complete Motors
32
Apr 7, 2016 01:39 PM
BfloG35
Audio/Video/Electronics
Oct 16, 2015 05:22 PM
TurTLe*
Sep 29, 2015 01:43 PM
