Couple AVIC-D1 INSTALL Questions
Old Jul 4, 2005 | 01:18 AM
Inno's Avatar
Hey I just got my D1 in and I'm going to install. Had questions about 3 wires.
1. Pink - Car Speed Signal Input - Where do you connect this exactly (manual says speed wire from ECU)? Not sure where that is! I assume if I ground it instead, the deck thinks I'm not moving. Will the GPS still function correctly?
2. Green - Parking Brake - I assume this tells the GPS it is ok to allow you to enter in destinations etc because you are parked. So if I want to set it up to always allow me to play with my GPS, even while driving (understand it is dangerous, but for a passenger), what do I connect it to? 12V or G?
3. Violet - Reverse Input - I'm not going to use a backup camera. So do I just ground this wire?
I appreciate anyones help who has done this already. Thanks guys!
Old Jul 4, 2005 | 01:35 AM
SagiSRP's Avatar
1. it is the white/green wire on the harness with 4 wires only
2. I grounded mine, but I have a kenwood unit, not sure if it will work with the pioneer
3. it is the purple wire that runs along the driver side floorboard into the trunk. Not sure if you really need to do it, but I did it
Old Jul 4, 2005 | 02:26 AM
Inno's Avatar
White/Green wire on harness with 4 wires only. Ok thank you. Where is the ECU? Passenger side floorboard area?
I will ground the parking brake, and hookup the other.
Thanks very much!
<EDIT> ECU is under passengers dash.
Thanks for the help all! I will post pics of my AVIC-D1 after I put it in. This is an 05 6MT. Hopefully I can get around to it tonight or tomorrow.
chinee
Jun 10, 2024 07:48 PM
Muski_G
Dec 1, 2023 11:11 AM
rezendvous420
May 31, 2020 01:26 PM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
Soumilg
Jul 18, 2015 12:33 PM
