LCD question?
Old Jul 5, 2005 | 11:26 AM
my_Gthang's Avatar
LCD question?
if i put an lcd in my car do i need to add an FM modulator? and if so has anyone hooked one up is it a DIY or do i have to pay someone?
thanks in advance!!!
Old Jul 5, 2005 | 12:09 PM
MiloX's Avatar
Not sure what you are asking.
What would the signal source be for the LCD? Both audio and video.
Old Jul 5, 2005 | 12:26 PM
my_Gthang's Avatar
baiscally i want to put two lcd in the headrest and run it off my PS2, just wondering how hard is it to install the fm modulator?
Old Jul 5, 2005 | 02:39 PM
my_Gthang's Avatar
Help?!!! does anyone know if i have to take out the radio just to hook up the ant. for the FM modulator?
Old Jul 5, 2005 | 03:58 PM
Meatshackle's Avatar
Deep Sea Moderator
To install the fm modulator you need to get to the back of the receiver. If you're going to do that you should get the PAC unit, assuming you don't use your sat button. The fm modulator sounds like crap.
Old Jul 5, 2005 | 04:04 PM
my_Gthang's Avatar
which pac unit? and how hard is it to install? sorry for so many questions...just lost...
Old Jul 5, 2005 | 04:36 PM
Deep Sea Moderator
Pac unit for nissan/infiniti. It plugs into the back of your head unit and gives you 2 aux inputs you can access through your sat button. I think it was about $75 and more than worth it. 2 RCA inputs that go directly into your head unit. Much better sound than the fm modulator.
Installation is easy. Once you get to the back of your head unit you just unplug one harness and plug in another.
Old Jul 5, 2005 | 08:50 PM
Inno's Avatar
Ok what are you trying to do here? If you just want to run 2 rear monitors off a PS2, and have the sound come through your stereo, it's not too hard.
Obviously you need to run video from the PS2 to both monitors.
If you plan to use an FM modulator for the audio portion, there is nothing involved with the deck. Just connect the modulator to the PS2. You usually get them with 1/8" stereo jack inputs, so you'll just need an RCA to 1/8" female converter. You don't need to do anything with the stock deck but tune it to whatever station your FM modulator is transmitting on.
Hope that helps.
Old Jul 5, 2005 | 09:24 PM
my_Gthang's Avatar
Originally Posted by MillersG
Dude dont waste your money on a modulator..they all sound like crap even with every filter available...Go with the PAC and you will be happy! Trust me Ive been there!
do you have any daytime pics of the rear headrest?
Old Jul 5, 2005 | 09:27 PM
my_Gthang's Avatar
Hope that helps.
so your telling me i dont have to go behind my headunit to hook up anything?
i dont need to hook up any kind of ant.?
Old Jul 5, 2005 | 10:29 PM
god_of_cpu's Avatar
StreetDeck.com Developer
Usually when you talk about an "FM Modular" in terms of car audio it refers to a permenatly installed FM transmitter that connects inline with cars antenna and will require you to mess with the head units connections to install it. A device referred to as strictly an "FM transmitter" on the other hand, does the same exact thing, but does not connect to the antenna, but rather just transmits on an open station.
Both do the same exact thing and both terms technically can and are used interchanably. The only real benefit to installing a "Modulator" is that by hooking directly into the antenna, it can cut off the connection to the antenna when its transmitting and will feed a more powerful signal directly into the antenna with less interference. I find in reality though, modulators make little practical difference compared to a similar quality transmitter. In any case, your not going to get great sound. The PAC audio is definitly the quality way to go, but if you don't care that much, you might as well just go with a transmitter given the difficulty of removing the head unit.
Old Jul 6, 2005 | 12:17 AM
my_Gthang's Avatar
where can i get one of these "fm transmitters"? man i feel like a noob...but thanks guys for all you insight!!!!
Old Jul 6, 2005 | 12:34 AM
Inno's Avatar
How many installs have you done before? If not much, I'd suggest just transmitting over FM. If you have done a few, obviously the PAC is the way to go. Hardwired will obviously produce better sound, but if you want cheap simple and dirty, get the transmitter. You can get one from just about anywhere. The ones with the 1/8" jack, you could use one from an Ipod. It doesn't really matter.
Old Jul 6, 2005 | 09:37 AM
god_of_cpu's Avatar
http://www.google.com/search?q=fm+transmitter
