cant see pictures in DIY forums
Old Jul 14, 2005 | 06:19 PM
GedOut's Avatar
for some reason in most of the posts for DIY and stereo i only see file names
instead of the pictures what should i do?
can u help?
thanks
I need DIY for door panle removal?? 2005 g35 coupe?
Old Jul 15, 2005 | 02:18 AM
mr_ecktid's Avatar
can u help?
thanks
I think when the server changed or was moved a lot of the links were lost.
Door panel removal is fairly straightforward.
I'm assuming the coupe's doors are similar to the sedan's, if so...
1. There is a square-shaped plastic disc in the space of the door handle. Use a flathead to pop it out, and a screw sould be revealed. Use a philips screwdriver to unscrew that.
2. Pop off the trim on the arm rest / handle by using a flathead underneath the bottom of the trim. There should be a small notch shaped for a flathead. two screws should be revealed. Repeat step 1 with those two screws.
3. Just pop the door panel off by pulling up and out. Hold it from the sides (works best for me) and try and squeeze your fingers in the small gaps. Make sure they pop out and nothing breaks.
4. The panel should still be connected by the door handle attachment and the window controller. Just unscrew the screws that attach them to the panel, and wa-lah! Door panel is removed.
Get back to me if this works out for you. If not I can post some pictures about it.
This shouldn't take more than 5-10 minutes.
-Mark
Old Jul 15, 2005 | 02:34 AM
rcdash's Avatar
Some threads have been recreated with the pics back in - it can be tough to find them - sometimes you need to go to the 2nd or 3rd page...
The site admins might be able to find what you need...
Old Jul 15, 2005 | 06:30 PM
nyckid's Avatar
yes please, i also need to access the DIY how to remove the coupes door panel.... need to see whats rattling inside, its driving me nuts...
is it easy to put back on or no?
Here's the original thread for the door panel removal, but the links are all dead for the pictures...
https://g35driver.com/forums/showthr...&highlight=DIY
Tolboothwilley™
Exterior-Vendor
Jul 28, 2016 12:42 AM
yassy
Aug 9, 2015 07:31 PM
newg37
Jul 26, 2015 09:32 AM
HypedAndy
Southern California
Jul 21, 2015 03:46 PM
