BOSE 6X9 Removal?
Old Aug 27, 2005 | 05:05 PM
Sam Siador's Avatar
BOSE 6X9 Removal?
Does anyone know how to remove the rear speaker grilles on the rear deck?
I removed the panel in the trunk but the speakers are screwed in from the top, I tried removing the upper speaker grilles, but they don't appear to just snap off! I did a search on the forum, but didn't come up with anything that really helped! If anyone out there knows how to pot those speaker covers how about some info & pics.
Old Aug 27, 2005 | 05:18 PM
94gxe's Avatar
Try this site: http://www.carstereohelp.com . Select 'Car Stereo Removal' and then 'Infiniti' in the left column
Old Aug 27, 2005 | 06:25 PM
Espresso's Avatar
If it's a coupe, you can only remove the 6x9 speaker from the top. Same for the speaker grills. There's a DIY somewhere on this site but I don't have a link. It's not an easy process since you basically have to remove your rear seats and the two side panels. From there, you can remove the rear dash panel and clearly see how the speakers are bolted.
Old Aug 27, 2005 | 06:28 PM
MikeyMike's Avatar
Rollin On Dubz
I asked an audio shop if they could remove it...they said its a MAJOR PAIN IN THE @$$. I think you have to take the seats out to get to it. I also asked the dealership about taking it out and they said the same
Maybe they're wrong, never actually tried it myself.
Old Aug 27, 2005 | 07:52 PM
blazinZ's Avatar
well that sux... i just bought some 6x9's to complete my system, i going to have to see about this.
Old Aug 28, 2005 | 03:50 AM
drsifu1's Avatar
Staff ALUMNI
20 Year Member
to remove 6x9 in coupe:
1- remove rear seat bottom by pulling hard straight up
2- remove rear back rest by removing 2 nuts (12 or 14 mm)
3- remove both rear qtr panels by pulling it to remove the clips
4- remove driver and passenger seatbelts
5- remove both trim panels
6- if applicable, remove rear brake light
7- remove rear parcel shelf
8- gain access to the 6x9
this gives you a general idea on how to get to them. lot more specifics, but it should be fairly intuitive once u get started.
Old Aug 28, 2005 | 05:12 PM
Sam Siador's Avatar
So what your saying is the speaker grille covers are part of the package tray and they come off with the tray? Man what a PIA to get those speakers! All really wanted to do was remove the covers & the third brake lite & child seat hold downs to install to install a one piece cover on the tray!
Old Aug 28, 2005 | 06:11 PM
shooter's Avatar
It's not the critic......
drsifu1 has given you the general idea.....
here is one of the threads https://g35driver.com/forums/showthr...707#post600707
its really not that bad once you've done it once or twice .....the first time does seem rather ridiculous
Old Aug 29, 2005 | 10:42 AM
Sam Siador's Avatar
Thanks a lot Shooter! Just what I've been looking for
Old Aug 29, 2005 | 11:13 PM
shooter's Avatar
no problem
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
Ninjay16
Audio/Video/Electronics
11
Feb 26, 2018 06:14 PM
DEMoLITIoN
Apr 20, 2016 06:57 PM
dcsbh1
Oct 1, 2015 03:15 PM
