has anyone replaced front 6.5 with components on bose system?
Old Aug 29, 2005 | 11:12 PM
g35lay's Avatar
i was wondering if anyone has replaced their front speakers with components. if you have, how do they sound? the reason i ask is because i've been told not to replace the bose speakers with aftermarket speakers. i was told i'd have to replace the whole system. something about aftermarket speakers are'nt compatible with the bose premium system. is this true? someone please clarify this for me. thanks....
lay
Old Aug 30, 2005 | 01:13 AM
Pearl05G's Avatar
Its true to a point. A decent set of 2Ohm components will work fine. Although it is still strongly suggested to use an aftermarket amp with components.
Old Aug 30, 2005 | 01:22 AM
Keith N's Avatar
I replaced the Bose speakers with MB Quart Premium 6.5" Components and 6X9" in the rear with an Alpine 4 channel amp. It is a huge improvement in sound quality and enjoyment.
Old Aug 30, 2005 | 07:53 AM
khsonic03's Avatar
+1 with Pearl05G's response. 2ohm speakers will work, but just do yourself a favor and get an amp.
Old Aug 30, 2005 | 01:42 PM
g35lay's Avatar
thanks for the response guys. so, it's ok, as long as i use a seperate amp for the components. thanks....
Old Aug 30, 2005 | 04:39 PM
rcdash's Avatar
it will work fine and sound fine with the stock AMP. the 4 ohm speakers will be quieter than the rears so you will have to adjust the fader appropriately. I had this setup for awhile before I upgraded everything.
So you could get components first, try it out, then decide...
Old Aug 31, 2005 | 07:12 PM
Forte's Avatar
Fosgates
Old Aug 31, 2005 | 08:16 PM
MikeyMike's Avatar
Rollin On Dubz
What if you have an aftermarket Headunit pushing 50wx4...do you still need an amp for components?
Old Aug 31, 2005 | 09:56 PM
Espresso's Avatar
Yes. It would be recommended.
Old Aug 31, 2005 | 10:20 PM
khsonic03's Avatar
An HU pushing 50wx4 is probably pushing more like 12-25w RMSx4. You have to consider that the size of an aftermarket HU is nowhere near the size of an aftermarket 4channel amp...and that is for a reason. A seperate amp is much more efficient/powerful than an HU. HU's are usually way overrated, and often rated in peak power, not RMS.
Old Sep 1, 2005 | 02:22 AM
coop's Avatar
I plan on buying a G35 later today and i have a set of these waiting for her when she gets home.
Old Sep 1, 2005 | 09:07 AM
audiphile's Avatar
Nice choice coop...on the car and the speakers. Be sure to post pics when you pic her up.
Old Sep 1, 2005 | 01:30 PM
netwireless's Avatar
I am going to upgrade the speakers soon. Here is what I'm planning to do:
Replace fronts with the Infiniti 6 1/2" component system (6010CS).
Replace the rear door speakers with the Infiniti 6 1/2" speakers (6012I).
Replace the rear sub, which I believe is only a 6x9 speaker, with a good reference Infiniti 6x9 speaker.
I want to keep the factory Bose head unit and the amp. Anyone has done something similar to this? Any opinions?
coop's Avatar
oh i will just waiting on insurance right now w00t w00t
Old Sep 1, 2005 | 01:38 PM
rcdash's Avatar
I would skip the 6 x 9 and go with a "regular" sub...
