Reference site is up!
Old Oct 7, 2005 | 09:56 AM
amthar's Avatar
http://digitalwheelz.com/diy/
Only contains whatever I could find in the forums that I thought was useful. Any other suggestions are welcome. No suggestions are welcome too, because they probably suck anyways (kidding... i think
Old Oct 7, 2005 | 10:25 AM
dabarn1's Avatar
Dude that is awsome. I have the entire manuel for the 2004 G35C in PDF format if you want to post it.
Old Oct 7, 2005 | 10:29 AM
amthar's Avatar
I have it too. I think it's considered illegal to post it though, otherwise I would have
I'll probably just post instructions on how to get a copy. Plus it's 153MB and God_of_CPU would like me to keep it under 200 megs or so, and I'm already at 133 with all of the exhaust links.
Thanks for the compliment on the site Just don't look at the code, lol
Old Oct 7, 2005 | 12:11 PM
dabarn1's Avatar
I'm doing the blinker mod this weekend now, thanks
Old Oct 7, 2005 | 07:18 PM
Gee Im Fast's Avatar
^ Same here...but can someone explain why there are two styles of blinking per se. I mean in his videos, hes got the alternating routine and in the second video they are synchronized...I mean I know I can do it either way I want by using a relay but I would guess wiring it with the headlight blinkers signal wire would keep them IN synchronization (video 2)...any thoughts?
Old Oct 7, 2005 | 08:37 PM
NM, I read the DIY section. It depends on whether the heads are on or if just parking.
Old Oct 7, 2005 | 10:19 PM
skaline's Avatar
You could always just post a link to THIS PAGE
Someone already posted the manual online.
Old Oct 8, 2005 | 12:42 AM
Any leads for the 05?
Old Oct 8, 2005 | 01:04 AM
xswl0931's Avatar
The site is a good start, but we should do something like this:
http://350z-tech.com/zwiki/Main_Page
Where people can contribute quite easily
Old Oct 9, 2005 | 03:50 PM
Silverbolt's Avatar
I was reading the blinker mod... wth? I explains so much and makes it so complicated, that I dont understand anymore! "K.I.S.S"... keep it short and simple.
The bumper light as a postive and a ground. The dual filament blinker has a ground, a constant possitive, and a possitive for blinking.
The bumper lights have two wires... what wires do they tap into? A diagram would make this so much easier to visualize.
Old Oct 9, 2005 | 04:08 PM
suprasam's Avatar
kiss
kiss-keep it simple stupid
Old Oct 10, 2005 | 12:28 AM
Just cut the black wire from the side marker, its long enough to reach either the green/white (drivers side) or the purple/white(passanger side) where you will use a wire tap to attach each pari together. Remember you only cut the black wire from the sidemarker where you have enough slack to tap into the blinkers wires.
Just use a wire tap on both sides. You don't need to make the extension. I did it this weekend and works fine.
Old Oct 10, 2005 | 05:35 AM
Silverbolt's Avatar
Thanks. See! This mod only needed a paragraph to explain... not an entire diy write up
suprasam, I re-worded it as "Keep It Short and Simple" because I didnt want to offend anyone by throwing out the word "stupid"
Old Oct 10, 2005 | 08:45 AM
amthar's Avatar
This really is not a thread for getting help on the DIYs. You can see on the DIY who wrote it and on which site/forum, so I would advise posting in the appropriate forum or contacting the original DIY author. None of these were authored by myself, simply copied or linked from other places. You're guaranteed to get much better support with your own thread in the appropriate place/to the appropriate person!
Thanks for using the site, glad it could be of service
Old Oct 10, 2005 | 03:20 PM
^ What you said really doesn't make sense for the only reason as this serves as a bump anytime anyone posts, or else no one would ever see this thread or know about the site!
