bose wiring diagram
Anyone has 2004 sedan Bose wiring diagram, I am getting ready to install a subs. I did a search and cant find it
. Also, how do you power and ground your new amps? do you run your powers to the battery?
Thanks in advance!!
. Also, how do you power and ground your new amps? do you run your powers to the battery?Thanks in advance!!
Grounding your amp is done via solidly attaching it to a sturdy, unpainted metal part of the body of your car (not something metal attached to the body, as in, don't use your seat tracks, for example).
You need to run a new power wire from the battery to wherever the amp is to power it.
I would recommend getting an amp kit from your local car audio shop. It's a bit more expensive then if you bought all the stuff adhoc, but it's going to be easier if you're not experienced with car audio installations.
Get this amp kit and you'll be fine.
http://www.knukonceptz.com/productDe...?prodID=eKo-K4
It's a lot cheaper than getting one at any local shop.
Thanks for great info.
Where do you run your power wires? Do you run it on the driver side or the passgener side?
also what location do u drill the hole to feed the Power wires to reach the battery?
For those that hook up the switch to power up your amps? which wires did you use to remote turn on your amps?
Ninjay16
Audio/Video/Electronics
11
Feb 26, 2018 06:14 PM
DEMoLITIoN
Apr 20, 2016 06:57 PM
master111
Oct 6, 2015 01:36 AM
