Audiophile Question
Old Oct 24, 2005 | 12:13 AM
realgone's Avatar
Widdle ya into kindling
Audiophile Question
I have this.
Phoenix Gold XS2500 2-Channel Amp Specifications
* Amplifier Type: 2-channel
* RMS Power @ 4 Ohms: 125W x 2 @ 13.8V
* THD at 4-Ohm RMS Power: n/a
* Bridged RMS Power @ 4 Ohms: 500W x 1 @ 13.8V
* Speaker Level Inputs: Yes
* Preamp Outputs: Yes
* Built-In Crossovers: HP/LP
* Bass Boost: 0 - 18 dB
* Frequency Response: 20-20,000 Hz
* Signal to Noise Ratio: >100 dB
* Fuse Rating: 2 x 30 amps
Was going to use a Kicker S10L7, but my buddy is taking way way too long on a box. It was a 2 ohm speaker.
Now my best bet (I think) with the 4080 box is the JL Audio 10w6v2 which is 4 ohm. Will I have any problems with this combo? Any advice on how to hook it up.
Sub Info......
Free Air Resonance (Fs): 28.5 Hz
Electrical “Q” (Qes): 0.497
Mechanical “Q” (Qms): 8.458
Total Speaker “Q” (Qts): 0.469
Equivalent Compliance (Vas): 1.18 cu. ft. / 33.4 liters
One-Way, Linear Excursion (Xmax)*: 0.60 in. / 15.2 mm
Reference Efficiency (no): 0.149%
Efficiency (1W/1m)**: 83.7 dB SPL
Effective Piston Area (Sd): 51.4 sq. in. / 0.0332 sq. m.
DC Resistance (Re): 6.30 ohm***
Nominal Impedance (Znom): Dual 4 ohm
Thermal Power Handling (Pt): 400W
Driver Displacement: 0.068 cu. ft. / 1.9 liters
Net Weight: 14.4 lbs. / 6.4 kg
Old Oct 24, 2005 | 12:22 PM
el_duderino's Avatar
If you are using a two-channel amp bridged mono to a single-voice-coil 4 ohm subwoofer, I don't see that you have any options in how to hook it up.
What is your question exactly? You are supplying all sorts of specs (most of which have zero to do with sound quality)... but I don't know what you are looking for. Reassurance?
bryanr
Drivetrain
Sep 30, 2015 06:31 AM
JG_G35
19 Inch
14
Sep 19, 2015 09:04 PM
migurus
Sep 5, 2015 09:39 PM
TheBay
Sep 3, 2015 03:27 PM
erich2780
Sep 3, 2015 03:23 PM
