A/c Technical Question
Old Dec 12, 2005 | 01:53 PM
planetstereo's Avatar
i have an 03 6mt w/navigation.my problem is my air conditioner.when i put the temp control on 60 it gets ice cold ,when i go to 61 it stops for a sec then blows heat anyone know what could cause this?
Old Dec 12, 2005 | 04:15 PM
Beowulf's Avatar
The auto mode is meant to control the temperature for you. When you set it at 60 then move it to 61 it will try to heat from 60 to 61. The system does not care of you have the A/C on or off it will heat to the temp you specify. You really shouldn't have a need to be setting it to 60 anyway it doesn't help it cool any faster. If you want to force it make sure its in manual mode and you will have less problems.
Old Dec 12, 2005 | 05:48 PM
gizsf's Avatar
I had the exact same issue after my alarm install. It was the temperture sensor under the steering column....it got unplugged.
Old Dec 12, 2005 | 06:29 PM
GRider35c's Avatar
^yeah, the rubber hose thingy? or is there a wire under there?^
Old Jan 5, 2009 | 04:08 PM
AARONHL's Avatar
I have the same exact problem and the in-cabin temperature sensor is connected correctly. Anyone fix the issue?
Old Jan 6, 2009 | 03:23 AM
gizsf's Avatar
Double check the sensor, maybe it's loose, wire yanked out, or the contacts are corroded. I think your issue is most likely under your steering wheel, not positive on the sedan location though. Not sure, but there could be another sensor since we have dual zones.
Old Jan 6, 2009 | 01:46 PM
AARONHL's Avatar
I replaced the in-cabin sensor with another one and nothing has changed.
Old Jan 7, 2009 | 03:51 AM
gizsf's Avatar
How /when did it start? Had any work done at the car around the time or what was the last work or service done on the car.
Old Jan 26, 2009 | 08:41 AM
nicallnet's Avatar
I have an 04 Coupe and this problem recently happened to me. Has anyone found a solution other than the in-cabin sensor?
Old Jan 26, 2009 | 08:39 PM
AARONHL's Avatar
Not yet, the Nissan dealer said my HVAC was fully functional. Let us know if you find anything.
champppy
Mar 31, 2020 12:25 PM
baker2795
Sep 2, 2015 06:00 PM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
Rehman2009
Jul 27, 2015 03:23 AM
