TvAndNav2go Gorund wire.. where to install??
Old Dec 25, 2005 | 12:37 PM
g35driver05's Avatar
Where are you grounding the "gorund" wire for the TVAndNav2go Plug and play UNIT??
I am tapping power from the cig lit. but where are you guys putting the "ground wire" that is part of the plug and play conector?
Thanks
Old Dec 25, 2005 | 01:30 PM
GRider35c's Avatar
you can put it under ANY metal screw... does that help??
Old Dec 25, 2005 | 03:25 PM
lol thanks... i wanted to know where ppl were putting it to get the best grounding and avoid any lines on the screen..
Old Dec 26, 2005 | 01:12 AM
Otacon132's Avatar
i grounded it directly to the cig lighter's ground
Old Dec 26, 2005 | 03:39 AM
Gee Im Fast's Avatar
There is a difference bewteen ground and earth, fellars....ground is ground and creates the loop with the power....the thick black one with a circular crimp is earth and is to reduce electrical noise...your car is properly gorunded...so like mentioned before, any metal screw! There is no "just right" place to reduce lines....lines come from the circuit itself and signal filtering, this you will never change.
With that said, I gounded mine with that black jumper that is on the back of the Navi chasis...the one that seems to run along from one corner to the other after you remove the navi console, its about 3 inches long...I just lifted up one end then re screwed after adding in the tvandnavtogo module earth.
Old Dec 26, 2005 | 10:19 AM
Gee IM fast.. thanks alot thas where i was planning on grounding it wit that screw.. just wanted to make sure! thanks guys
G-MAN (CANADA)
Canada
Sep 7, 2015 03:51 PM
3000vr4tt
Sep 7, 2015 12:48 AM
SilverG123
Engine - Electrical
Sep 4, 2015 01:12 PM
