Front speaker foam thickness
Install experts....
Assuming one was to use a 1" spacer ring for the speakers on the front doors. How thick of a foam weather strip will be needed to seal the face of the spacer ring to the backside of the door panel?
1" spacer sounds about right. I used the OEM speaker frames for the spacers so the distance and alignement weren't a problem. I used some medium density 1/2' x 1/2" foam.
You can easily check for alignment and compression by popping out the window controls and looking down with a flashlight while pushing the door panel in place. At least on the 04's you could.
From looking at mine (3/4" spacers) I really think the 1" spacers would allow a good seal just using the oem foam on the door panels. Make sure you align the speaker perfectly so that the door panel edges don't hit your speaker. Good luck!
Tolboothwilley™
Exterior-Vendor
Jul 28, 2016 12:42 AM
