help...New System issues?
Old Apr 12, 2006 | 09:54 AM
e420x's Avatar
Mod Junky!
So I get my new system installed which consists of a JL 500/5, DLS up front and rear and a JL 10w3v2 . At first my sub stops working and we come to find out the new sub is now somehow blown, then next I see my left front components stop working. What happens is they play for awhile, then start to get real static and then the left side stops completly. Also the rear 6.5's are sounding like they are out of phase..like a very big delay.
So as you can assume I am very annoyed. I have a blown sub, and my left side does not work properly. Its weird cause the mids and highs play ok for awhile, then the left front side gets static then it dies. If I wait a day the left side comes back on again but the rear still sounds very strange. What could this be?
Old Apr 12, 2006 | 11:34 AM
GXCLUSIV's Avatar
Im guessing might be problem with the amp. Switch rca's for your front components and see if the right side also quits working. Of course check all your speaker wires. Also connect sub to another channel output, just to make sure if they are actually blown.
Old Apr 12, 2006 | 11:38 AM
SI_G35Coupe's Avatar
e420x.... are you sure the left side speakers going in and out aren't a result of the known problem with the stock CD changer? that has happened to alot of us... the left side on mine goes out sometimes until you give the CD changer a little whack.
Old Apr 13, 2006 | 10:30 AM
e420x's Avatar
Mod Junky!
Weird thing is the rear speakers issues only seem to happen when playing the XM radio. The left side is playing fine today of course
Old Apr 14, 2006 | 08:49 AM
BigSash's Avatar
you do the install yourself?
where did you buy the amp?
chinee
Jun 10, 2024 07:48 PM
11bEMT
May 27, 2022 03:13 PM
RA102223
Aug 15, 2015 09:24 PM
Phalanx
V36 Audio, Video & Electronics
Aug 10, 2015 11:31 AM
joedaddy1
Jul 28, 2015 02:58 PM
