Headrest questions
Old Apr 15, 2006 | 07:37 PM
06slvrG's Avatar
Headrest questions
I have found a place where I can get Directed headrests, monitors, dvd player, 3 input/output switch, etc for around 1000 bucks. I am thinking of doing it, but their part numbers only go up to 2004. Does anyone know if the headrests in an 04 are the same as an 06? It also doesn't specify coupe or sedan, are they the same? I thought I read on here that the sedan was angled more than the coupe. If that is the case, would coupe headrest look out of place in a sedan (in case that is what I am buying)? It looks like a fairly easy kit to install and If I add the tvnavtogo to it I will be set. A tad more money than I would like to spend, but cheaper than I have been able to find anywhere else.
thanks for any help you guys can provide
Old Apr 15, 2006 | 10:48 PM
BigSash's Avatar
hope you don't mind whiplash when u get rear ended.
i probably wouldn't change my headrests in my sedan. Unless maybe I had some monitors custom installed in the stock head rests.
Active restraint is a great technology I am not willing to lose on my daily driver.
gl
bryanr
Drivetrain
Sep 30, 2015 06:31 AM
JG_G35
19 Inch
14
Sep 19, 2015 09:04 PM
migurus
Sep 5, 2015 09:39 PM
TheBay
Sep 3, 2015 03:27 PM
erich2780
Sep 3, 2015 03:23 PM
