Another ipod install, simple/cheap with full function and stealth
Old Apr 30, 2006 | 07:25 PM
BigSash's Avatar
Ah, thank you for the compliments, yes your notion about the fact that it loses the line out when it loses power seems correct.
Old May 3, 2006 | 06:36 PM
Galikanokis's Avatar
So does this mean that if I want to use a dock connector (OR PocketDock which splits the dock into an audio jack and firewire) I can ONLY LISTEN when the iPod is charging!?!?! DAMMIT! It looks like there's no way around killing the battery!
Old May 3, 2006 | 10:27 PM
nsurg's Avatar
What is it that you want it to do? Any options are possible.
I could care less about full discharge of battery prior to recharge. I bought it at costco, where all products are sold with a lifetime return-if-unsatisfied policy... beats best buy's warranty extension program, no?
If you want it to NOT charge, that's an even easier install... Use a product like this plugged into the AAI-NIS2:
http://cgi.ebay.com/iPod-STEREO-LINK-6ft-RCA-Adapter-Cable-use-w-4G-mini_W0QQitemZ9720836850QQcategoryZ48680QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
I also just found this product that skips the internal amp/volume control/3.5mm jack that the belkin has, but gives you a charge and an RCA out from the dock... seems like a ripoff at $35, but probably a theoretically cleaner signal:
http://stores.channeladvisor.com/bag...itemid=4713460
Or you could just wire a simple power cutoff switch from radioshack to the 2nd product and kill the power charge as you desire. While the belkin needs power to give a signal, it does not appear that the second product would need power for an audio output to stay alive.
You can make it work for whatever you want, I just used the belkin because it is cheap and available... and I hadn't found that 2nd product in time! I guess I'd move to that second product if I were unhappy with my current sound, but I'm very pleased as it is.
willdogs
Dec 8, 2015 11:32 AM
Jiggerjuice
Oct 5, 2015 02:33 PM
RA102223
Aug 15, 2015 09:24 PM
bishop977
Audio/Video/Electronics
Jul 31, 2015 02:29 AM
mjfenix
Jul 17, 2015 02:07 PM
