harness missing/non-functional ground?
Old May 11, 2006 | 01:44 AM
woshiagni's Avatar
Anybody who has done a DD install, have you had problems with the Nissan harness not providing a good ground? This is driving me nuts...
I've done a search on this... at least with the good keywords I could think of. I'm using a Scosche NN03B adapter, and it seems like all the pins are good, except that the "ground" (black wire) has a Vdiff of about +5v!! Using the harness ground as ground also causes wild fluctuations in the ignition and constant +12v lines. Not good.
I thought something was shorted so I removed the Scosche harness and found that probing from the Nissan harness side shows the same thing (I think ground on that side is a gray wire with green stripe?). No good ground on the harness either. Plugged the stock radio (non-Bose) back in and it seems to work okay though, which I think is odd.
Anyone?
Marlin84
Apr 1, 2020 12:52 PM
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
Ninjay16
Audio/Video/Electronics
11
Feb 26, 2018 06:14 PM
the93owner
Sep 28, 2015 10:37 PM
