350z front springs on my 03 coupe. Would they fit ??
Old Jul 10, 2009 | 01:48 AM
andres's Avatar
Old Jul 10, 2009 | 10:59 AM
RBull's Avatar
Rated M
yes
Old Jul 24, 2009 | 12:19 PM
Shawn87's Avatar
Everything between the G35/350Z suspension is interchangable.
Old Jul 24, 2009 | 02:13 PM
andres's Avatar
springs
it dont matter if the Z is an 06, and my coupe is an 03 ??? im planning just to put them in the front. and leave that stock infinity springs in the rear. What you guys think ??
Old Jul 24, 2009 | 09:32 PM
tiguy99's Avatar
Andres, do a search. There are tons of threads out there on this.
350z and G35 coupe/sedan springs especially the fronts are all the same spring rate among the 03-07.
324 ft/lbs springs. Only difference is that 350z springs are .5" shorter than the G coupe springs and 1" shorter vs G35 sedan springs.
Hence the reason a lot of us upgraded to 350z springs for the mild drop our cars so badly needed
For me, I went with 04.5 350z revised springs for my 05 G35 sport coupe...long story short...same ride just .5" lower...no camber kit necessary
Check my garage for more info
Old Jul 27, 2009 | 06:17 PM
thescreensavers's Avatar
Mr.202?
G35 coupe is .5 drop and 350z is a 1inch drop. many people on this forum do Z in the front and G coupe in the Back to get the G/Z Drop on a sedan, I am planning to do this my self. And yes the springs fit. But if you dont have the sports suspension I am think you are going to need to replace your shocks very soon.
Old Jul 27, 2009 | 08:18 PM
RADIOGUY21's Avatar
slight correction, G35 and Z front springs have a 314lb spring rate FYI.
xplosive1
Steering & Suspension
Aug 1, 2015 03:01 AM
netcbc
Steering & Suspension CDN
Jul 24, 2015 01:59 PM
netcbc
Jul 24, 2015 11:25 AM
AustinErkl
Drivetrain
Jul 18, 2015 05:44 PM
