DIY: Tokico D-Spec Extension for G35 Coupes
Old Dec 21, 2008 | 11:04 PM
  #31
thedroppedpearl's Avatar
same DIY for 04 sedan? want those extensions bad!
Old Dec 22, 2008 | 11:09 AM
  #32
RBull's Avatar
Rated M
^do you have premium package? If so apparently you can access top of shock to screw on extension without drilling, lowering shocks etc.
Old Dec 22, 2008 | 03:45 PM
  #33
^ya i have the premium package so it sounds like just take out the headrests?
Old Dec 23, 2008 | 09:03 AM
  #34
RBull's Avatar
Rated M
I'm not sure what the difference is between regular and premium cars. I don't have a sedan. I've just read the premium is an easy fix. The key is you need to be able to access the top of the rear shocks to screw on the extension. However you can do with your car?? Do the rear seats move or recline? Hopefully someone will chime in with a prem sedan.
Old Jan 29, 2010 | 11:44 AM
  #35
tiguy99's Avatar
I'd like to know as well. I have a premium sports model coupe and would like to order these extensions.
I was thinking of dropping the rear shocks today to adjust them BUT if it means I only have to drop them once to install these extensions I'd rather do that instead of dropping them over and over to find the right setting.
Also, keep in mind the seller I bought the shocks from did not give me any adjusting key at all. Will I have to order them too (pink part on top of the extensions shown on page one) or are they part of the extensions everyone's talking about?
Old Jan 29, 2010 | 01:35 PM
  #36
tiguy99's Avatar
Just ordered my set from Stillen!!! Woot. Can't wait to install them next week
Old Jan 30, 2010 | 08:31 AM
  #37
RBull's Avatar
Rated M
The pink part is the adjuster for the rear extensions and integrated as one piece. It comes with the extensions.
You'll also need the adjusting tool for the fronts which won't have the extensions. The person you bought these from should have supplied it.
For the coupes you need to drill an existing hole a little larger, from below into the rear deck. The hole comes very close to the child seat anchor covers on the rear deck. The extensions get fished up under the anchor covers. Flip down the seat, remove the covers and adjust your Dspecs.
The DIY here explains it well.
Old Feb 4, 2010 | 01:05 AM
  #38
SacG35's Avatar
nice diy!
Old Jun 21, 2010 | 11:15 PM
  #39
nyckid's Avatar
Will this DIY work with the extensions for Stance GR+ coilovers? I just hope that they are long enough to reach those anchor covers thats what I'm concerned about.
Old Jun 23, 2010 | 05:42 AM
  #40
NJzFinestG's Avatar
how long did the install take??
Old Jun 25, 2010 | 04:01 PM
  #41
G35fromPA's Avatar
Install takes about an hour per side, taking your time and working carefully, including the shock install itself.
Old Jun 26, 2010 | 05:08 PM
  #42
RBull's Avatar
Rated M
^+1.
Old Jun 26, 2010 | 09:50 PM
  #43
mitsuboost's Avatar
^ werd
Old Jun 28, 2010 | 06:45 PM
  #44
NJzFinestG's Avatar
i have a set for sale if ne 1 needs them.
Old Jun 29, 2010 | 08:31 PM
  #45
RBull's Avatar
Rated M
Originally Posted by mitsuboost
^ werd
How about a useful contribution?
