350z brembos Fit 04 G35
Old Feb 9, 2009 | 07:41 PM
Repins's Avatar
Will a set of Brembo's from a 350z bolt right up to my 04 G35 coupe?
Old Feb 10, 2009 | 11:09 AM
RBull's Avatar
Rated M
Yes, with calipers, rotors and lines.
Old Feb 10, 2009 | 12:43 PM
INF G'd Up's Avatar
co-sign
Old Feb 10, 2009 | 03:10 PM
Jeff92se's Avatar
Red Card Crew
I think you need one set of OEM brembo bolts for their the front or rear. Other than that, yes.
Old Feb 10, 2009 | 03:22 PM
nghiars's Avatar
+1 get the dust covers from the brembo set up if you can too.
Old Feb 11, 2009 | 09:17 PM
Repins's Avatar
Do i need new mounting hardware for a set of brembo's off an 05 G35? And do i need new lines as well?
Old Feb 15, 2009 | 09:01 PM
learningman's Avatar
Talking
I can tell you... I did the same thing to my 04 5AT.
FR & RR Calipers
Lines
bolts for rear calipers (stock fronts will work)
brake Master cylinder "M215T" <- If you do not get this the brakes will not hold any pressure you will constanly have to be pumping.
My Brembos are also off a 350z.
Old Feb 16, 2009 | 07:10 PM
Repins's Avatar
Any idea of the OEM 17's from the 04 will fit with the brembos? Or will i need some spacers?
Old Feb 17, 2009 | 02:18 PM
RBull's Avatar
Rated M
^others on here have posted saying they don't work.
Old Feb 17, 2009 | 02:58 PM
Repins's Avatar
They just dont fit at all or i need a spacer? And if i need a spacer any idea on the size?
Old Feb 18, 2009 | 10:14 AM
RBull's Avatar
Rated M
^Sorry, can't help with that.
Old Mar 23, 2009 | 10:25 PM
SHOWKING's Avatar
FR & RR Calipers
Lines
What kind of lines and calipers did you use? Also if im putting 03 G35 Brembo's on a 06 Coupe do i still need a brake master cylinder?
Old Mar 23, 2009 | 10:32 PM
Repins's Avatar
I did my swap not long ago. You DO NOT need a new master cylinder. I used some Stainless lines that i got from one of the vendors here.
However i believe to put Brembos on the 06 you would need some kind of mounting bracket for the rear.
netcbc
Exterior - Body Parts CDN
Aug 21, 2015 09:50 AM
laksjd84
Jul 24, 2015 05:12 PM
netcbc
Steering & Suspension CDN
Jul 24, 2015 11:25 AM
AustinErkl
Drivetrain
Jul 18, 2015 05:44 PM
LoSt180
Jul 15, 2015 08:31 AM
