Diff. between Gold and Red Stillen sways?
Old May 24, 2006 | 11:33 AM
dream_G35's Avatar
Hey like it says in title.....i hear at first Stillen made them in gold then changed to red but i wanted to know if they are still 5way adjustable and equal in thickness to the red ones? thanks.
Old May 24, 2006 | 11:34 AM
InTgr8r's Avatar
Staff ALUMNI (retired)
Red ones are HOT
... IIRC, no dif
Old May 24, 2006 | 01:01 PM
dream_G35's Avatar
so the only difference is color? am i correct?
Old May 24, 2006 | 01:10 PM
InTgr8r's Avatar
Can't say absolutely; maybe someone else will chime in.
But I don't recall anyone commenting on a spec change... just color.
Did you find some used ones???
Old May 24, 2006 | 02:03 PM
wa2good's Avatar
It is only the color that is different. Because Stillen is a marketing company that market and private labels parts that their supliers actually make, these sways were first made by the suplier (name witheld) in a golden yellow at first, and now they are finished in red. They have the same specs.
Old May 24, 2006 | 02:50 PM
dream_G35's Avatar
good to hear thanks, updates and pics by end of week
Old May 24, 2006 | 06:59 PM
Chico's Avatar
Originally Posted by inTgr8r
Red ones are HOT
... IIRC, no dif
Old May 28, 2006 | 08:47 PM
RBull's Avatar
Rated M
Red ones are HOT
... IIRC, no dif
Thanks. I feel better about my red ones now.
Old May 29, 2006 | 12:28 PM
trey.hutcheson's Avatar
I seem to remember seeing a video of the sway bars being produced with this variable bending machine. Quite slick actually. It was also at stillen if I'm not mistaken...
Old May 29, 2006 | 01:31 PM
g35rcr's Avatar
the cost for stillen to make them gold was higher than the red
Old May 29, 2006 | 02:27 PM
dream_G35's Avatar
what bushings should i get, i also read somewhere that i should only get the rear because poly in the front doesnt fit....
i was thinking of getting end link bushings and collar bushings or is that not necessary
Old May 30, 2006 | 06:27 AM
optimystic06's Avatar
To answer original question; no difference except color. To VRT guy:
Actually Stillen owns the supplier of the swaybars as well so that marketing and private labeling info you provided is incorrect. ....you are probably thinking Stillen is getting them from Eibach, which they are not. Almost all items w/ Stillen logo are made in house.
Old May 30, 2006 | 11:44 AM
RBull's Avatar
Rated M
haha; however gold is heavier
Old May 31, 2006 | 11:38 AM
dream_G35's Avatar
bump for this question:.....i ordered Energy Bushings from Summit racing for the front and rear sway bar....now i've been reading not to bother with the front bushings and reuse the OEM bushings because they won't fit or something like that, when i remove those front sway bushings should i lube them again or just throw them on. Also im using rhino ramps to lift the front should be fine correct?
Another question: For the rear (and front) should i buy endlink bushings or will it be fine without (i dont want any creaking). Rear i also will be using rhino ramps since i doubt it is necessary -correct me if im wrong- to remove the rear passenger wheel to remove the sway bar.
thanks for the help. if bushings come today pics will go up tomoro
Old May 31, 2006 | 12:20 PM
g35rcr's Avatar
i just used what came in the kit along with my stock parts and no problems
