Eibach Problem
Old May 25, 2006 | 01:23 AM
05skylineG's Avatar
Eibach Problem
I just got done installing the Eibach Pro Kit. The height looks exactly the same as stock height. I took it for a little drive and it still looks the same, im woundering if i installed them wrong or something. On the springs in the rear they are closely coiled on one side then they get wider at the other side. (hope that makes sence) Wich side goes where (bottom/Top) ? Could this be the problem. before install i compared them to my stock ones and they looked to be the same height but like i siad the Eibachs have more coil on one side then the other? Please help..... Part# on Box 6365.140
Old May 25, 2006 | 01:26 AM
LightsOutG35's Avatar
Really, same height? Thats very odd. It should have dropped it 1.1" in the front and 1.0" in the rear. Should see a HUGE difference.
Old May 25, 2006 | 01:38 AM
Basheer's Avatar
Call the Cops
might have to wait for the springs to settle
Old May 25, 2006 | 01:39 AM
05skylineG's Avatar
thats what i thought. I dont know whats wrong? I installed a camber kit and toe bolt also but i dont think that has anything to do with it. I checked the part number with the one eibach has on there web site and it appears to be the same. anyone know???
Old May 25, 2006 | 01:40 AM
05skylineG's Avatar
but it should still show some sort of a drop. Right?
Old May 25, 2006 | 01:49 AM
Chico's Avatar
Something is definitely wrong. I got the prokit on my car and I saw the drop as soon as the car came off the rack. Call Eibach for support tomorrow and tell him what you did and they can tell you if you did something wrong.
Old May 25, 2006 | 01:39 PM
05skylineG's Avatar
i called eibach today and they gave me the part numbers to which spring goes where and everthing is right, i dont understand? WTF, why is it still the same height?
Old May 25, 2006 | 02:03 PM
kenchan's Avatar
im sure your springs are seated correctly to the mounts, but double check if the are.
that's very odd... you should immediately see a nice 1" drop and then settle for another 1/2"
Old May 25, 2006 | 06:13 PM
sliderg35's Avatar
You should notice at least a little change, but it does take a couple of weeks for the drop to take full effect.
Old May 26, 2006 | 01:40 AM
w0ady's Avatar
fgc moderator
hope it works out. for those of you that have the pro kit, how do you like it? im thinking of getting it. also, did you all do camber kits or is it not necessary with a good alignment?
Old May 26, 2006 | 02:23 AM
truplay8's Avatar
THE BATMOBILE
did you buy it from another person on the site.........another is300tog35 incident??
Old May 26, 2006 | 12:04 PM
Espresso's Avatar
I had 350Z H-Techs installed and the drop is suppose to only be 3/4" F, and 1/2" R and I noticed a difference right away. Your springs should give you a bigger drop and you should see a dramatic change from stock right away. It may take a few days or a week to settle and be broken in but that's for fraction of an inch. It's not going to settle a full inch or something.
Old May 26, 2006 | 10:25 PM
sliderg35's Avatar
I have the Pro kit and I am very happy with the drop. It took weeks to drop to where it is now. The camber is noticeable and the dealer mensionned that it is out of whack on the last alignment, so I have a camber kit on the way. It will be installed in 3 weeks.
Old May 27, 2006 | 02:22 AM
w0ady's Avatar
fgc moderator
thanks. i guess ill have to check into camber kits as well. any you recommend?
Old May 27, 2006 | 03:01 PM
VIP-STATUS's Avatar
Keep in mind an inch is noticable ... but not that dramatic. I had a customer say the same thing when we did a set on a G35. Give it some time.
