full 350z suspension or just springs
Old May 28, 2006 | 11:48 AM
Dakkerz's Avatar
I've searched a lot on this and found a lot of useful information but still couldnt find this last part of my question. TIA for any help.
I found a good deal on unrevised 350z springs and shocks, just curious if I should just get the springs or both. I know the springs are a direct swap and the spring rates will match up with my current shocks, just curious is to whether or not changing the shocks will A) fit and B) offer any more improvements over G35 oem shocks.
Old May 28, 2006 | 01:55 PM
Gsedan35's Avatar
Here, I ran a search for you under "bounce" narrowed under my username. Feel free to cut and paste anything you find into this thread and post.
https://g35driver.com/forums/search....archid=1157524
Short answer is to say, only buy the 03 springs. If your going to buy oem Z shocks get 04.5+ ONLY.
Old May 29, 2006 | 12:07 PM
Dakkerz's Avatar
Thanks Gsedan35 I was able to find a lot of what I wanted to know from your posts. Like I said I did a search, but IMO the search feature on this forum isn't as good as it could be since you can't use +, and, or etc. functions.
Old May 29, 2006 | 12:15 PM
g35rcr's Avatar
i did both because the person sold it as a set cheap...the z struts were meant to be compressed for the z spring rate...
Old May 29, 2006 | 12:20 PM
Dakkerz's Avatar
Yeah, that's the situation I'm in. Someone offered up the springs and struts really cheap. Are you happy with them, or are you noticing any negative effects of the swap like excessive bounce or porposing?
Z1Motorsports
Suspension-Vendor
56
May 31, 2020 01:56 PM
laksjd84
Steering & Suspension
16
Jul 12, 2017 12:22 AM
linedr89
Aug 17, 2015 05:11 PM
xplosive1
Aug 1, 2015 03:01 AM
netcbc
Steering & Suspension CDN
Jul 24, 2015 11:25 AM
