Swift 350Z Springs Installed Pics (6)
Old Jun 2, 2006 | 08:37 PM
mr.almeida's Avatar
Swift Sport Mach 350Z
These springs are great. I used to have Tein SS-P's on my RSX Type S and I never felt any bounciness. These give me that same feeling and are real comfortable. They have yet to settle so i can only imagine how much more it'll drop when it does.
Old Jun 2, 2006 | 09:34 PM
kenchan's Avatar
not a bad drop. the rear could go another 10mm...
get some 15mm offset spacers for the front to fill up the tuck.
www.optionimports.com Kics spacers.
Old Jun 2, 2006 | 11:35 PM
johnbigbootie's Avatar
what year is your Coupe? Did you use the revised or unrevised Z springs? TIA.
Old Jun 2, 2006 | 11:46 PM
mr.almeida's Avatar
2004, I honestly don't know the difference between the two.
Old Jun 3, 2006 | 01:03 PM
nm3th's Avatar
johnbigbootie-
I think that you're confusing the swift springs with the oem 350z springs. The threadstarter did not use oem 350z springs; he used aftermarket springs made by swift for the 350z.
mr.almeida-
Looks good. Keep us posted once the spring settles and you get an alignment. I'm curious to see how much of an effect these springs have on camber, etc.
My only "turn-off" for aftermarket springs are the lower spring rates in the rear when compared to the sport suspension springs for an 05/06.
Old Jun 3, 2006 | 03:17 PM
Originally Posted by nm3th
johnbigbootie-
D'Oh!!! Damnit you're right...sorry
Old Jun 4, 2006 | 11:14 AM
Gsedan35's Avatar
Would be kinda curious for you to post the drop measurements (distance in inches from the top of the wheel well arch to the ground, all 4 corners).
Oem ride height is 27.32" front
Oem ride height is 27.64" rear
Old Jun 5, 2006 | 10:15 AM
DRG35R's Avatar
20 Year Member
G35 Coupe "Sport Package"
Is that for 18's or 19's or both?
jsimonk
Dec 22, 2023 03:49 PM
EPG35
Aug 16, 2015 04:52 PM
xplosive1
Steering & Suspension
Aug 1, 2015 03:01 AM
netcbc
Engine - Intake/Fuel CDN
Jul 24, 2015 02:21 PM
netcbc
Steering & Suspension CDN
Jul 24, 2015 11:25 AM
