Will a track 350Z Brembos work/fit on 05' G35 Sedan sport?
Old Jun 5, 2006 | 08:24 AM
NickS's Avatar
Like I said... A buddy has a 350Z with Brembos. He's going to get Stoptechs and I want to know if those Brembos will work on my Sedan? Even though my brakes are larger than the 04' G35 Sedan, I'm not sure about the size and specs of the Brembos.
This would be caliper and rotors I would be buying from him.
Old Jun 6, 2006 | 12:59 PM
myG35ZX's Avatar
They fit, just not the wheels over them. A spacer - a big spacer. But the brakes bolt on with no problem.
Old Jun 6, 2006 | 01:02 PM
ttrank's Avatar
Grocery getter
^+1
Change out your lines while you are in there.
Old Jun 6, 2006 | 01:40 PM
NickS's Avatar
passed on this but thanks for the responses.
Old Jun 23, 2006 | 05:47 PM
johnadlertech's Avatar
I swear I just tried the same thing. Tested the rear caliper, plenty of room. Even a stock 05 17" rim fit. So the front must fit the 18"s too, right? Not. I need 8-10mm more. I was so disappointed. I just assumed the sedan sport rims would work. Not sure if I want to do spacers. The OEM Brembo rims must have a ton of backspacing. But yet they look so similar.
I dont have track rotors so I left the stockers on for the test fit and noticed that they were not centered in the caliper (front). Do the track rotors for the brembos have a diffrent offset then the regular ones (pre 05 brakes)? Or is there some other problem?
netcbc
Exterior - Body Parts CDN
Aug 21, 2015 09:50 AM
laksjd84
Jul 24, 2015 05:12 PM
crazy_g35s
Jul 20, 2015 02:30 PM
mushu
Jul 15, 2015 03:55 PM
