Camber kit help
Old Jun 10, 2006 | 07:56 PM
smoke1's Avatar
Camber kit help
I bought a set of Zyoxx in 20 and put 255x35x20.
I need to install a camber kit to avoid the rubbin g on the fender.
Will the camber kits sold for any 350Z G35 coupe or sedan will fit on a G35X.
The best will be for one of you to measure and give me the distance you have centerline of bolt to centerline of bolt on your rear camber bar.
Thanks In advance
Old Jun 14, 2006 | 02:12 PM
KingoftheRoad1's Avatar
I have been looking for a camber kit for a different reason from yours. My front passenger side camber is out of spec when I went for an alignment. The shop guy told me to get a camber kit to correct the situation. So I have done quite a bit of research. The G35 sedan and the G35X have the same front camber set up. So the parts are the same. I think the Kinetix offers the best price.
Old Jun 24, 2006 | 05:04 PM
smoke1's Avatar
I need the rear (this is where the rubing happen)
but whatever if the front is the same the rear should also be the same.
thank you for your help
TwinTurboZ
19 Inch
Sep 26, 2015 06:11 PM
boostelevator
Engine - Power Adders
Sep 9, 2015 05:56 PM
jsimonk
Steering & Suspension
Sep 2, 2015 03:07 PM
