Greaseable Sway bar bushings
Jun 12, 2006 | 03:14 PM
FWIW, came across these....
Wide selection of sway bar bushings, including greaseable versions.
LINKY
Reply 0
Jun 13, 2006 | 12:31 PM
cool.
are any of your stock bushings wearing out? the rears looked fined on mine.
will check the fronts when i do the oil change next time.
Reply 0
Jun 13, 2006 | 03:10 PM
have you guys checked how much hotchkis sells their bushings only?
Reply 0
Jun 13, 2006 | 04:21 PM
Have any of you tried using teflon tape instead of grease? I did that on an aftermarket bar after the original bushings wore out and I had to replace them. Seemed to work really well, and it should never squeeze out.
Curt
Reply 0
Jun 15, 2006 | 01:12 AM
You can't use the Energy bushings for the front sway (endlinks may work). The stock brackets and bushings are ribbed and the smooth Energy bushings won't seat properly.
Reply 0
Sep 5, 2006 | 05:42 PM
^darn...I thought I just found what I've been looking for
Reply 0
