calling all Tokico D-spec or Esplier spring owners
i've had this set up for a couple of months now and just the other day, i noticed uneven tire wear...
so those of you with either just the Tokicos or the esplier gts or both, can you guys check your tires to see if you have uneven tire wear just in the rear...
if it was my inner tires wearing more, i wouldn't think much of it cus of the camber issue but, my problem is the opposite, my outter side of the tire is wear more than the inner side of the tire
i've seen several thread about tire feathering and wasn't sure if it i'm having the same tire feathering problem or if my problem is caused by either the tokicos shocks or the espliers gt springs
any comments or suggestions will be much appreciated
StreetStandard
Suspension-Vendor
Jan 18, 2016 03:36 PM
