so no body here has more outer tire wear than inner tire wear?
Old Jul 3, 2006 | 02:26 AM
techi13's Avatar
as some of you might have read my other thread about uneven tire wear,
so busy these days, i cant get the timing right to call my alignment place for the numbers (specs)after aligning my car...
but seriously, nobody here has experience the same problem with their tires?
-1.5 camber all around but yet experiencing more outer wear on the tires...
anybody?
Old Jul 3, 2006 | 08:12 AM
Klubbheads's Avatar
I can't see how that is possible with -1.5 camber.
Old Jul 3, 2006 | 08:19 AM
SilverII's Avatar
un....not here.... check your alignment again.
Old Jul 3, 2006 | 08:41 AM
JOKER's Avatar
CLUB MODERATOR
I got 22k on a car. no alignment done on it got same problem
My inside got more ware then outside. I spoke with a dealer he told me if it would be before 12k then they would change it but now they cant, and he also told me that tires only last bout 25k on a G and that it is normal to get that kind of ware cuz that is how your wheels setup on G. ???
Old Jul 3, 2006 | 08:48 AM
kenchan's Avatar
get an alignment and let us know your readings. did your dealer recently
do a left/right right/left tire rotation?
and no, 99% of the people here are getting inner tread wear than outer
including me... well, only on the rear.
anybody?
Old Jul 3, 2006 | 09:08 PM
techi13's Avatar
then, do you guys think its possible that a combination of my shocks being too firm in the rears and my aggresive driving thru turns is causing the uneven tire wear?
Old Jul 3, 2006 | 09:39 PM
kenchan's Avatar
are you driving through tight turns with rear breaking loose all the time?
if so, you could get the shoulder to wear out more...
Old Jul 4, 2006 | 01:42 AM
Klubbheads's Avatar
that is not possible unless u live at the track.
Old Jul 4, 2006 | 01:01 PM
techi13's Avatar
well, ive never tracked my car, but i have gone driving throu cannons like big bear or some twisties in palos verdes....
i've never broke loose the rears on dry pavement
i drive somewhat aggresively especially thru turns but, not like the way kenchan discribed it
Old Jul 4, 2006 | 10:33 PM
kenchan's Avatar
i recommend an alignment.
Old Jul 6, 2006 | 09:27 AM
Q45tech's Avatar
Alignment is a standard maintenance item that often is required every 7500 [15000 for sure] miles especially after any oem modifications that increase weight stress to correct for suspension bushing wear durometer hardness changes.
Alignment is the missetting of the suspension to compensate for deflections that occur under speedturning load.
Misalignment numbers are derived by factory for brand new vehicles [thus the wide range] to avoid warranty repairs as the component ages..........the midpoint of the range is usually the IDEAL setting at least when things are new!
Old Jul 7, 2006 | 12:58 AM
techi13's Avatar
thank you for all the inputs....i really really appreciate all your inputs to my problems
i'll be getting my alignment first thing next week
Old Jul 7, 2006 | 01:14 AM
silver g's Avatar
anybody?
You are lucky. I wish I had that problem. My tires wear on the inside although I was able to correct it somewhat with the stillen camber and toe adjusters. Have you checked your tire pressure? I have heard that running two low of tire pressure can cause outside edge wear.
Old Jul 7, 2006 | 02:04 AM
techi13's Avatar
jsut checked the tire pressures....there fine.
Old Jul 12, 2006 | 10:49 PM
techi13's Avatar
i'm such a retard...after jacking up the rear to inspect the tires more closey, i realized the tires wear is perfectly even...
btw, thanks everyone for your imputs
tiguy99
Mar 1, 2016 11:42 AM
netcbc
Wheels & Tires CDN
Sep 24, 2015 09:53 AM
