Front Strut Bar
Old Jul 6, 2006 | 09:29 AM
Calvin's Avatar
Overglorified Altima
STILLEN Strut Tower Bars
Part No. Application Type Price
307765 INFINITI G35 2003-2006 ; Coupe Rear $149.95
mynismo.com
Old Jul 6, 2006 | 10:20 AM
Soopa G's Avatar
mynismo.com
that's for the rear, I think everyone else is talking about the front one
Old Jul 6, 2006 | 10:22 AM
InTgr8r's Avatar
Staff ALUMNI (retired)
Stillen only has a rear.
But, VRT is now making a front one for stillen that works with the SC
Old Jul 6, 2006 | 10:26 AM
Archangel's Avatar
If you get a lower plenum like the Kinetix SSV, will a strut bar for the 350Z fit on a G?
Old Jul 6, 2006 | 12:28 PM
Spekterg35's Avatar
No. The 350z strut bar bolt holes will not line up to the G35. I believe the shape of the actual strut towers on the G are slightly different as well.
Old Jul 6, 2006 | 12:45 PM
Calvin's Avatar
whoops. overlooked that
Old Jul 6, 2006 | 02:54 PM
kavehdr's Avatar
The link that aHero4Eternity has is for a 350Z front straut bar. I think Stillen only has a read straut bar for G35 not a front bar.
Old Jul 7, 2006 | 12:07 AM
jonnylaw's Avatar
Anybody know if the ARC or VRT strut bar will fit over a 5/16 spacer w/ engine cover?
Old Jul 7, 2006 | 01:17 AM
wa2good's Avatar
The VRT STB will fit with any aftermarket plenum /plenum spacer. You will need to modify the engine cover if you decide to use one, and yes it will, and does work on the 06's
As far as the ARC brace , pretty sure it will not, good luck with that thing though.
Old Jul 7, 2006 | 03:37 AM
jonnylaw's Avatar
What kind of modification to the cover is necessary? A 350z cover won't do? Is this b/c of clearance issues w/ the hood? On the link to Arc's product, it shows it clearing the stock g35 engine cover. Is there that little clearance available that would not allow a 5/16 spacer as well?
Old Jul 7, 2006 | 01:49 PM
wa2good's Avatar
For the VRT STB, you will need to notch out the area of the plastic engine cover where the bar runs across. Like this........
The ARC will alow you to run an engine cover with the brace but you will have problems fittting the engine cover on with the spacer, and then the BRACE will not fit.
I am pretty sure the ARC brace will not acomidate a plenum spacer.
And , Yes, there realy is that little of room under the hood of these cars.
Old Jul 7, 2006 | 06:08 PM
Silverbolt's Avatar
Does anyone know for sure? 100% possitive the answer to whether or not an ARC will fit with a 5/16 spacer (w/o engine cover, of course).
Old Jul 7, 2006 | 10:53 PM
jonnylaw's Avatar
Wow, so the arc can clear an engine cover, but not a 5/16 space w/ no engine cover and the VRT can accomadate a spacer but not an engine cover w/out modification? Is a spacer that much thicker than the engine cover when its on? Is it possible to buy that custom carbon fiber engine cover that was posted on the pic w/ the VRT?
Old Jul 8, 2006 | 04:02 AM
Silverbolt's Avatar
Hes "pretty sure", but hes not 100% sure about the ARC fitting with a 5/16 spacer.
Does anyone know for sure, whether or not an ARC will fit with a 5/16 spacer?
Old Jul 8, 2006 | 07:01 AM
  #30
wa2good's Avatar
Yes
Yes
