Spacers/brembo Question?
Old Jul 18, 2006 | 01:45 PM
Mo's Tre' 5's Avatar
Question Spacers/brembo Question?
whats up everyone..i just recentally bought 19" Sevas S-stars. They are Black with a polished lip. 19x8.5 F and 19x9.5 R. Tire size is 245/35F and 275/30R. +20 offset.....i was just wonderin' if i needed spacers to clear brembos for these rims?....someone told me 5mm and someone else told me 2mm spacers ...im pretty lost when it comes to spacers...im hopin' someone on this forum can help me.....
'03 6mt....
Old Jul 18, 2006 | 05:37 PM
drunkin master's Avatar
You should of made sure that it did clear brembos before you bought them. Most sellings would know. I don't know if the spacers will clear your calipers or not. CAll the place you bought them from and ask.
Old Jul 19, 2006 | 10:07 AM
im actually buyin' it from someone on this forum...and he said i do need spacers!...he say 5mm spacers...but i just wanted some more info. just to be sure!
Old Jul 19, 2006 | 10:33 AM
kenchan's Avatar
that really depends on the design of the spokes and rear disc
(on the wheel) size. typically though, you should be able to clear the
fronts with +20mm. the rear is usually not the problem as the caliper
is smaller.
Old Jul 19, 2006 | 12:50 PM
Tonys-G's Avatar
I hate spacers, I had a set on my 300zx and the hub rings barely covered the hub maybe 1/16 in (didn't fill me with confidence) and they tend to get rust inbetween, all in all I was never too happy with them
prob because I am kind of **** about my car, any way I would be carfull using spacers especially if it pushes the rims so far out that they are no longer hub-centric
Just my .02 cents worth
bryanr
Drivetrain
Sep 30, 2015 06:31 AM
JG_G35
19 Inch
14
Sep 19, 2015 09:04 PM
migurus
Sep 5, 2015 09:39 PM
TheBay
Sep 3, 2015 03:27 PM
erich2780
Sep 3, 2015 03:23 PM
