question on lowering
Old Jul 18, 2006 | 09:36 PM
aszatk01's Avatar
hey guys.... i have Ruff Racing 19's on the ride now with 245 up front and 275 in the rear. I also have Eibach Pro Kit from a 350z. i'm pretty sure that the 350z version lowers even more than the G Pro Kit springs (is this correct?).
my main question is, with the 275's in the rear (Dunlop Direzza low-profile), will i have any rubbing issues if i drop it with the 350z Eibach ProKit??
thanks in advance.
Old Jul 18, 2006 | 09:49 PM
silver g's Avatar
The G35 pro kit actually drops the front of your car 0.1" more than the 350Z Pro kit. The rear is the same 1.0". I have this setup with Volk 19's and 245F/275R and I do not rub.
Old Jul 18, 2006 | 10:14 PM
aszatk01's Avatar
^^^thanks a lot. that makes me feel a bit better.
do you have any pics by any chance?
thanks
Old Jul 18, 2006 | 10:17 PM
aszatk01's Avatar
OH...and whats this whole camber kit stuff???
is it NEEDED or recommended to use this with the proposed setup?
i'm also guessing i wont need it without the springs....
Old Jul 18, 2006 | 11:41 PM
silver g's Avatar
Check my car domain site in my signature for pics (I have the G35 Eibach Pro Kit Springs.) My front and rear camber and rear toe was off REAL BAD when I put the Eibach pro kit on. I was forced to get Stillen Front and Rear Camber adjusters as well as Stillen rear toe adjusters to correct the the camber and toe problems. If you do not mind spending a lot of money on tires then do not worry about it. But if you do mind I would recommend that you invest in some camber and toe adjusters.
Old Jul 20, 2006 | 06:17 PM
aszatk01's Avatar
^^^thanks. anyone know more specifically about teh 350z pro kit?
rezendvous420
May 31, 2020 01:26 PM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
