Lowering the car?
Old Jul 21, 2006 | 06:02 PM
kavehdr's Avatar
Lowering the car?
Hi,
I heard that you can lower the car? Just wondernig what's the deal. What are the benefits and what's the downside? How much does it cost?
Thanks
Old Jul 21, 2006 | 06:06 PM
Canadian's Avatar
Canada, eh?
Just get some springs - Tein S Tech's are what I have getting installed tomorrow.
It will improve handling a bit but will also increase the wear on your tires unless you get a camber kit as well. It also looks better.
It costs like $150-200 for springs and then install can be like $100-200 unless you know the owner of the shop which I do
Old Jul 21, 2006 | 08:09 PM
M4Gunner's Avatar
^ or you can install them yourself. however, if youre asking what lowering a car does, id guess that you dont know how to do the work yourself, so.. yeah.. have them installed!
Old Jul 21, 2006 | 08:27 PM
m@rky's Avatar
Originally Posted by kavehdr
Hi,
Thanks
wow, that's a hell of a rumor
yeah go with the S-Techs
Old Jul 21, 2006 | 08:29 PM
Calvin's Avatar
Overglorified Altima
downside: if you dont be careful youll scrape..a lot
so just be aware when you go in or out of driveways and dips
but yes it does improve handling
you can also get coilovers..but thatll cost you a pretty penny
Old Jul 21, 2006 | 08:52 PM
Petoria's Avatar
i know a lot of people have h-tecs but are s-techs better?! and how about the sports suspension from the dealer do they take those out or what....sorry i dont know much about suspension
Old Jul 21, 2006 | 09:06 PM
RBull's Avatar
Rated M
Check the suspension forum
Old Jul 21, 2006 | 09:18 PM
Finiti35's Avatar
FGC South Florida BOD
The only benefit to lowering your car on H-techs or S-techs is going from a 3-finger wheel gap (stock) to a 2-finger gap (or slightly less with the S-techs). You won't improve the handling until you upgrade the dampers. In most cases, you'll actually worsen it - e.g. the S-techs. A pitiful 274lb spring in the rear, body lean and bounciness galore as well as tirewear if you don't do anything about aligning it back to factory specs.
Old Jul 21, 2006 | 10:01 PM
Ja_Ja_Genau's Avatar
Do it right for the first time. Don't get springs - get coilovers.
Stock shocks will die sooner with shorter springs ... car will be bouncing like a ~!@#%.
Old Jul 21, 2006 | 10:04 PM
savefatkids's Avatar
or shocks and springs...
Old Jul 22, 2006 | 02:08 AM
truplay8's Avatar
THE BATMOBILE
depending on your budget and how low you want to drop will determine which springs you want.........search
Old Jul 22, 2006 | 09:23 PM
Canadian's Avatar
Canada, eh?
Easier said then done without an air compresser
Old Jul 22, 2006 | 09:57 PM
M4Gunner's Avatar
why would you need an air compressor?
Old Jul 23, 2006 | 04:08 AM
g35vixen's Avatar
From: LAS VEGAS [ a sunny place, for shady people ]
So the SPRINGS arent as stiff.
Old Jul 23, 2006 | 04:10 AM
M4Gunner's Avatar
so whats not as stiff? arent we talking about springs, or did i miss something?
