I want to replace OEM Brembo rotors for drilled
What drilled rotors are you guys using to replace the OEM Brembo rotors? I'd like the two piece rotors front and rear, but I'll also consider one piece drilled rotors.
Did you notice better performance after the swap?
What kind of rotors are you using and where did you get them?
I got authentic crossdrilled Brembo replacements from www.lildevilmotorsports.com I found them to the cheapest for the rotors and for shipping. I believe they have warehouses all over the country (I think one in FLA) so shipping should be ultra fast. I received mine in a few days. In hindsight, I probably should have spent the extra money and got the 2 piece Stoptech rotors to shave some weight, but whatever. For the price, these will work!
Authentic Brembo rotor are either drilled or slotted....NOT BOTH
