Abs/slip/vdc Off Lights On?????
Old Aug 9, 2006 | 08:59 PM
20004DSC's Avatar
Just got new tires and alligned and now the ABS light, SLIP light, and VDC OFF light are on. Also after the allignment the right front side is sitting about 3/4 of an inch higher than the rest of the car. At first I thought the the spring hadn't settledall the way but that was more than 100 miles ago. Please help me figure out what is going on.
Thanks,
Brian
Old Aug 10, 2006 | 10:10 PM
20004DSC's Avatar
bump...
Please help!!
Old Aug 31, 2006 | 09:29 PM
midnightrunner's Avatar
I have this same problem, except it didnt happen until i got the alignment...anyone have this problem solved...I checked my brake fluid...as i've heard fixed it, but brake fluid level is good
Old Sep 1, 2006 | 12:27 PM
RockG's Avatar
throttle body probably went bad. go to the dealership to have that part replaced. (it's covered under the warranty)
Old Sep 1, 2006 | 04:57 PM
TopTech's Avatar
I had the same problem after having the front brakes serviced. It took more than 7 trips to the dealer and 2 ABS controllers to solve. Getting it there WITH the lights on helps, they can plug it in and read the error.
Old Sep 2, 2006 | 08:58 AM
G35 Mass's Avatar
Check the speed sensors on each wheel, and make sure your brake fluid is to the upper full mark
Old Nov 13, 2006 | 01:14 PM
ttrank's Avatar
Grocery getter
This just came up on my car too. Going to take it in soon.
Old Nov 13, 2006 | 05:18 PM
Mark350GT's Avatar
yeah those lights have been on my dash for a good year now. haha
Old Nov 14, 2006 | 04:13 AM
Pro-Skyline03's Avatar
this actually happened to be right after i took out the stock wheels and put on some 19in wheels, the emergency BRAKE light, the SLIP, and the VDC OFF lights all stay on, why would it do that? maybe the sensors are going crazy or something
Old Nov 14, 2006 | 11:30 AM
G35_Foo's Avatar
for me when those lights showed up and it started to sputter something got caught in my throttle (lol) so it that was an easy fix for me.
what i think is who install the suspension didnt put it in correctly so one side is high causing the brake fluid to shift.
Old Nov 14, 2006 | 01:59 PM
GreenGoblin's Avatar
The goblin resurrection
^ that could be that a spring is twisted in wrong
Old Nov 14, 2006 | 02:03 PM
i just called infiniti, they said it could be your brakes!! im taking it in tomorrow morning, ill let you guys know if the lights came off......
Old Nov 14, 2006 | 02:07 PM
Aznteazer's Avatar
do u have SPC camber kit installed?
Old Nov 14, 2006 | 02:14 PM
eyustfu's Avatar
I would check the speed sensors. The only real way of checking it that I know of is with the Consult II. One of mine went bad and thats what caused the lights but I just haven't gotten around to fixing it.
You might also try getting another alignment to see if it fixes it. There should be a sensor in the steering column I believe that may possibly throw the ABS/Slip/VDC Off light if the alignment is off.
Old Nov 22, 2006 | 02:40 PM
Casetay's Avatar
1ClssyG
Yeah this is caused by not having enough brake fluid and can also be because your brake pads are wearing down. It just did that on mine the other day but since I have navi it popped up saying low brake fluid.
Machine Head
19 Inch
Mar 16, 2016 08:55 PM
cmesidewayz
Sep 29, 2015 09:28 PM
neight
Interior
Sep 21, 2015 05:35 PM
Jnm07
Sep 5, 2015 01:16 AM
