camber question
Old Aug 22, 2006 | 03:38 PM
gspothawaii's Avatar
camber question
say i drop in the tein flex coilovers and edfc, will i have to purchase the camber repalcemetn parts for the front and rear. i was on stillen.com, and they recommended to me the front and rear camber replacement parts (or are they jerkin me for cash?).
http://stillen.com/product_list.aspx...006&subcat=181
Old Aug 22, 2006 | 03:54 PM
Gsedan35's Avatar
Depends on how much your going to drop the car. Coupes and sedan's have different oem min/max specs, so we'd need to know what you drive and how much lower your going to run.
If you have a coupe and will only do a .8"-1" drop you might want to get the car aligned and see where you stand. If your going to drop past that, I do support their suggestion that you also buy alignment correction parts. Though IMO, I would not get their rear kit but the SPC kit, unless your adverse to how you have to grind out toe cam slot. Also you might want to consider the new SPC front arm kit at $429 and the new SPL kit at $499 vs the Stillen front kit.
Old Aug 22, 2006 | 04:24 PM
G35BASTARD's Avatar
I was told that with Tein Flex, if you don't drop it too low, there wouldn't be a need for a camberkit. Just after installing it, and lowering the car, take it to the alignment shop and ask if your car can be aligned, they will tell you if you need a camber kit.
Old Aug 22, 2006 | 04:48 PM
Q45tech's Avatar
Don't accept inside oem wide range parameters calculate the exact midpoint and use that as the guide if tire life is important or braking distances.
Excessive front camber beyond 0.7 reduces stopping distances.
jsimonk
Dec 22, 2023 03:49 PM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
netcbc
Steering & Suspension CDN
Jul 24, 2015 01:59 PM
Soumilg
Jul 18, 2015 12:33 PM
