View Poll Results: Is lowering the front only a good idea?
yes
14
13.08%
no
93
86.92%
Voters: 107. You may not vote on this poll
droppin the front
Old Sep 18, 2006 | 09:39 AM
BEK27's Avatar
droppin the front
Is it easy to lower just the front end?
What is your experience with handling, trac-control, ABS, ...?
I have too many fat friends to bring the back down.
Attached Thumbnails droppin the front-0915-001.jpg   droppin the front-0915-020.jpg
Old Sep 18, 2006 | 11:28 AM
kenchan's Avatar
what are your rear rates again?
Old Sep 18, 2006 | 11:29 AM
filanj's Avatar
I don't know the aerodynamic's of it, but weight distribution wise you will put extra weight on your front tires and your tires will wear twice as easily and roughly... def check out your max load on your tires before you seriously consider it... lookin at those sweet rims it doesn't look like a heck of a good idea...
Old Sep 18, 2006 | 12:30 PM
06BLACKMT's Avatar
paint your sideskirts instead
Old Sep 18, 2006 | 12:58 PM
Calvin's Avatar
Overglorified Altima
lol +1
Old Sep 18, 2006 | 05:03 PM
FL-G35's Avatar
LMAO!!!! Now that was funny. The only way you could do this right would be to buy an adjustable suspension. My front is lower than my rear, not by much but it is. As far a tire wear, the lower you go the worse off your camber is. Not much you can do unless you get camber kit, cusco, stillen..etc. You can always tell your friends to loose weight and lower the whole car....lol
Old Sep 18, 2006 | 05:45 PM
az1anbeethoven's Avatar
lol...that was harsh but true
Old Sep 18, 2006 | 07:05 PM
5150DS's Avatar
You can if you want to look like a 60's muscle car.
Old Sep 18, 2006 | 10:32 PM
robbie51981's Avatar
not only would that look retarded it will kill your tires. Im not sure but it looks like you are running 18s...maybe 19s. If you lower your front only I will give you less than 1 year before you have to put new tires on it. It will throw your whole car out of wack. The car is RWD and traction would decrease significantly.
On the lighter side of things...I love that color g.
Old Sep 19, 2006 | 03:09 PM
seddon's Avatar
I lowered the front(only) of my X with coupe sport springs just to make the car sit level. The rear was lower than the front due to my stero setup. No problem yet and it's been about six months now.
Old Sep 19, 2006 | 05:50 PM
kidtronix's Avatar
Optional
I put lead weights in my side skirts to pull the car down. Pretty much lowered the whole thing evenly. Saved a ton of money on springs. Now I can afford those triple-chromed dubs. Well really they're 15's. But I'll keep 'em clean.
Old Sep 19, 2006 | 06:00 PM
2006_G_coupe's Avatar
I was thinking about doing the same thing.!! I did this on my maxima and it was ok.The car was totally even all the way around.!! Id say go for it.
Old Sep 19, 2006 | 07:31 PM
KJG35's Avatar
All or none
lower the whole thing or nothing
Z1Motorsports
Suspension-Vendor
56
May 31, 2020 01:56 PM
derres
Aug 28, 2015 03:27 PM
linedr89
Aug 17, 2015 05:11 PM
miata007
Aug 17, 2015 04:36 PM
netcbc
Steering & Suspension CDN
Jul 24, 2015 01:59 PM
